Can you store the incoming data from the sensors in another location?
Hi, please excuse the newbie question.
I haven’t got anything set up just yet, but this is the situation. We will have 56 sensors around our property, and I need to have the data from those sensors stored on our NAS, perhaps in a CSV / JSON file.
Is this possible to do automatically? From the little that I understand - data by default is stored in the postgres DB, so is there a way to (using built in functionality), to have two funnels as to where the data will go? Or would we need to write a script to do this for us through the API / direct interaction with the DB?
I’m guessing that if I was to do it manually, then I would need to write an SQL script to grab the data, and put that into a format of my choice?
Thank you :slight_smile:
There are many integration options available:
https://www.chirpstack.io/docs/chirpstack/integrations/index.html
None are enabled by default, including the PostgreSQL integration. That one’s probably your best bet for exporting to CSV, though.
You may need to write a simple script to get the data from MQTT or Postgres and save to a text file.
Thank you for your reply @IoTThinks - please excuse my ignorance, but with an MQTT broker such as mosquitto, would my script interact with it via mosquitto’s API?
Also, @bconway / @IoTThinks - if I need to wipe data from my DB (we’re hosting network + app server on an EC2 instance, so space is a constraint) - can that only be done via interacting Postgres? And with that in mind - would it make more sense for me to use the Postgres vs an MQTT broker?
P.S: I do apologise for my ignorance - I’m trying to visualise things as we can’t physically set anything up at present
Thank you :blush:
