when I try to connect to chirpstack with the grpc java for this code I get an exception:
ManagedChannel channel = ManagedChannelBuilder
.forTarget(serverAddress)
.usePlaintext()
.build();
I am using this version of the java api: 4.6.0-test.4 and this is the exception:
Servlet.service() for servlet [dispatcherServlet] in context with path [] threw exception [Handler dispatch failed; nested exception is java.lang.NoClassDefFoundError: io/grpc/ForwardingChannelBuilder2] with root cause
java.lang.ClassNotFoundException: io.grpc.ForwardingChannelBuilder2
at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:641) ~[na:na]
at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(ClassLoaders.java:188) ~[na:na]
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:520) ~[na:na]
at java.base/java.lang.ClassLoader.defineClass1(Native Method) ~[na:na]
at java.base/java.lang.ClassLoader.defineClass(ClassLoader.java:1012) ~[na:na]
at java.base/java.security.SecureClassLoader.defineClass(SecureClassLoader.java:150) ~[na:na]
at java.base/jdk.internal.loader.BuiltinClassLoader.defineClass(BuiltinClassLoader.java:862) ~[na:na]
at java.base/jdk.internal.loader.BuiltinClassLoader.findClassOnClassPathOrNull(BuiltinClassLoader.java:760) ~[na:na]
at java.base/jdk.internal.loader.BuiltinClassLoader.loadClassOrNull(BuiltinClassLoader.java:681) ~[na:na]
at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:639) ~[na:na]
at java.base/java.lang.Class.forName0(Native Method) ~[na:na]
at java.base/java.lang.Class.forName(Class.java:375) ~[na:na]
at io.grpc.ManagedChannelRegistry.getHardCodedClasses(ManagedChannelRegistry.java:139) ~[grpc-api-1.51.0.jar:1.51.0]
at io.grpc.ManagedChannelRegistry.getDefaultRegistry(ManagedChannelRegistry.java:103) ~[grpc-api-1.51.0.jar:1.51.0]
at io.grpc.ManagedChannelProvider.provider(ManagedChannelProvider.java:43) ~[grpc-api-1.51.0.jar:1.51.0]
at io.grpc.ManagedChannelBuilder.forAddress(ManagedChannelBuilder.java:39) ~[grpc-api-1.51.0.jar:1.51.0]
at
