we’ve successfully set up LoRaServer and RabbitMQ (RabbitMQ instead of Mosqiutto because we’re already running it). Please note that we don’t use default ports.
I can access the WebUI via https://10.0.2.4:9080 but can’t access the API via https://10.0.2.4:9080/api - that just redirects to the regular WebUI. Do we have to enable the API console or so?
Edit: Oh wow, that’s strange. It works in Chrome but not in Safari.
I have same issue.
But my case is chrome.
When I try to connect to domain:8080/api
It’s redirect to domain:8080/#api/organizations
There is no special logs of app server
We have a LoRa Server Instance which sits behind an NGINX proxy for SSL and the likes, everything is working as expected (Including the Frame Logs!) apart from the API.
