I’m using the lora project since few mounth with my sensor and it work fine.
i justeinstall the same image of my os on new raspberry to use the project in this bord, i let the sam key …, it work fine for one of my node but the seconde node can’t connect, i’m using th OTA, but the node try lot of time request => accept …
I try to
- disable the frame counter.
- msb to lsb for app key.
- restar node and all server.
i check the log of the “gateway bridge” & “loraserver” & “lora-app-server” when my node send join request, but it’s look like there are any error , i really don’t undestand.
LORA-GATEWAY-BRIDGE
Apr 24 13:28:00 paclido-gat lora-gateway-bridge[1143]: time="2019-04-24T13:23:23+01:00"
level=info msg="gateway: rxpk packet received" addr="127.0.0.1:48252"
data="AAgHBgUEAwIBBGE3djc3MjGo5Ed1lgY=" mac=abcdef1010101010
LORASERVER
Apr 24 13:28:00 paclido-gat loraserver[1332]: time="2019-04-24T13:28:00+01:00" level=info
msg="device-session saved" dev_addr=01560379 dev_eui=3132373776376104
msg="device-activation created" dev_eui=3132373776376104 id=1297
msg="device updated" dev_eui=3132373776376104
LORA-APP-SERVER
Apr 24 13:28:00 paclido-gat lora-app-server[1240]: time="2019-04-24T13:28:00+01:00" level=info
msg="js: request received" message_type=JoinReq receiver_id=0102030405060708
sender_id=000000 transaction_id=2958745989
msg="device-keys updated" dev_eui=3132373776376104
msg="js: sending response" message_type=JoinAns receiver_id=000000 result_code=Success
sender_id=0102030405060708 transaction_id=2958745989
It was working fine in my last gateway whith :
- loraserver 2.0.0
- lora-app-server 2.0.0
And now i’m using version 2.7.0.
In the log of the loraserver it’s clearly writteen : device-activation created
Thanks
