as explained here:
The building process seems broken.
tiib
2
Can you ensure that you are using the make devshell and that your are inside the docker-container?
As described in the issue for me the build process works, so I assume it might be something with your set up.
Also the test via github workflows are working see: Generate 4.0.2. · chirpstack/chirpstack-rest-api@677b923 · GitHub
