Can't delete gateway
Hi there,
I am currently unable to delete a gateway via UI. The delete button stays greyed out when I type in the name to confirm. The specific gateway has a space at the end of the name, probably an input error. If I try to delete a gateway without a space at the end, it works fine. Is this a bug in the UI?
'xxx_gateway ’ → not deletable
‘xxx_gateway’ → deletable
Is there anyway I can get around this? I tried to delete the gateway via http request without much success.
I deleted the whole tenant now. It works but is a bit of a pain obviously.
If you think this is a bug, then please create an issue here with all the steps to reproduce the issue so that I or somebody else can look into this:
