I have kerlink wirnet iStation and I would like to change the default EU868 8 Channels band to use different 8 frequencies. Can someone please help me with what set the rfconf:0 and rfconf:1 frequencies in the lgw.ini file so I can use my new frequencies below:
For command lines, you check check the below files.
/etc/lorafwd.toml => Packet Forwarder
/etc/lorad/lorad.json => Frequencies
This is for fevo.
ls /etc/lorad/fevo/
AS923-JP.json AU915-AU.json IN865-IN.json RU864-RU.json US915-US.json
AS923-TH-SG-HK-TW.json EU868-FR.json KR920-KR.json RU864-RU_Legacy.json
This guide is to connect a Kerlink gateway to ChirpStack using packet forwarder.
If you don’t have Kerlink Cloud, then use IP scanner to check for the IP of the Kerlink gateway.
Then https://IP
Or ssh to the IP and check my above file locations.
Well, then I don’t know already.
Actility usually even seldom publishes the user manual than Kerlink.
Usually, we have to contact Actility authorized partners to get the docs.
