Hi
I’m trying to run ChirpStack with docker compose and I faced problem with port changing. When I change ports for and in standard docker-compose configuration, I get errors like this. Ports 20246 and 30246 are both open and can’t handle TCP and UDP transition. I can’t open ports 8080 and 1700 on my VPS.
I tried to change port 8080 to 20246 manually in ChirpStack config to 20246, but also get errors.
chirpstack-docker_redis_1 is up-to-date
chirpstack-docker_mosquitto_1 is up-to-date
chirpstack-docker_postgres_1 is up-to-date
Recreating 8837cad6e814_chirpstack-docker_chirpstack-gateway-bridge_1 ...
chirpstack-docker_chirpstack-gateway-bridge-basicstation_1 is up-to-date
ERROR: for 8837cad6e814_chirpstack-docker_chirpstack-gateway-bridge_1 'ContainerConfig'
ce6d5fe09894_chirpstack-docker_chirpstack_1 is up-to-date
chirpstack-docker_chirpstack-rest-api_1 is up-to-date
ERROR: for chirpstack-gateway-bridge 'ContainerConfig'
Traceback (most recent call last):
File "/usr/bin/docker-compose", line 33, in <module>
sys.exit(load_entry_point('docker-compose==1.29.2', 'console_scripts', 'docker-compose')())
File "/usr/lib/python3/dist-packages/compose/cli/main.py", line 81, in main
command_func()
File "/usr/lib/python3/dist-packages/compose/cli/main.py", line 203, in perform_command
handler(command, command_options)
File "/usr/lib/python3/dist-packages/compose/metrics/decorator.py", line 18, in wrapper
result = fn(*args, **kwargs)
File "/usr/lib/python3/dist-packages/compose/cli/main.py", line 1186, in up
to_attach = up(False)
File "/usr/lib/python3/dist-packages/compose/cli/main.py", line 1166, in up
return self.project.up(
File "/usr/lib/python3/dist-packages/compose/project.py", line 697, in up
results, errors = parallel.parallel_execute(
File "/usr/lib/python3/dist-packages/compose/parallel.py", line 108, in parallel_execute
raise error_to_reraise
File "/usr/lib/python3/dist-packages/compose/parallel.py", line 206, in producer
result = func(obj)
File "/usr/lib/python3/dist-packages/compose/project.py", line 679, in do
return service.execute_convergence_plan(
File "/usr/lib/python3/dist-packages/compose/service.py", line 579, in execute_convergence_plan
return self._execute_convergence_recreate(
File "/usr/lib/python3/dist-packages/compose/service.py", line 499, in _execute_convergence_recreate
containers, errors = parallel_execute(
result = func(obj)
File "/usr/lib/python3/dist-packages/compose/service.py", line 494, in recreate
return self.recreate_container(
File "/usr/lib/python3/dist-packages/compose/service.py", line 612, in recreate_container
new_container = self.create_container(
File "/usr/lib/python3/dist-packages/compose/service.py", line 330, in create_container
container_options = self._get_container_create_options(
File "/usr/lib/python3/dist-packages/compose/service.py", line 921, in _get_container_create_options
container_options, override_options = self._build_container_volume_options(
File "/usr/lib/python3/dist-packages/compose/service.py", line 960, in _build_container_volume_options
binds, affinity = merge_volume_bindings(
File "/usr/lib/python3/dist-packages/compose/service.py", line 1548, in merge_volume_bindings
old_volumes, old_mounts = get_container_data_volumes(
File "/usr/lib/python3/dist-packages/compose/service.py", line 1579, in get_container_data_volumes
container.image_config['ContainerConfig'].get('Volumes') or {}
KeyError: 'ContainerConfig'
My configuration:
services:
chirpstack:
image: chirpstack/chirpstack:4
command: -c /etc/chirpstack
restart: unless-stopped
volumes:
- ./lorawan-devices:/opt/lorawan-devices
depends_on:
- postgres
- mosquitto
- redis
environment:
- MQTT_BROKER_HOST=mosquitto
- REDIS_HOST=redis
- POSTGRESQL_HOST=postgres
ports:
- 20246:8080
chirpstack-gateway-bridge:
image: chirpstack/chirpstack-gateway-bridge:4
ports:
- 30246:1700/udp
volumes:
environment:
- INTEGRATION__MQTT__EVENT_TOPIC_TEMPLATE=eu868/gateway/{{ .GatewayID }}/event/{{ .EventType }}
- INTEGRATION__MQTT__STATE_TOPIC_TEMPLATE=eu868/gateway/{{ .GatewayID }}/state/{{ .StateType }}
- INTEGRATION__MQTT__COMMAND_TOPIC_TEMPLATE=eu868/gateway/{{ .GatewayID }}/command/#
depends_on:
- mosquitto=
