I’m trying to use the Gateway-OS with raspberry-pi and a concentrator from a company in Brazil, the concentrator has the same configuration as RHF0M301, the only difference from the reset pin.
RHF0M301 reset pin 24
Radioenge concentrator = reset pin 26
I would like to know if I can change the settings to use pin 26.
this concentrator has gps:
GPS RXD - UART TX 8
GPS TXD - UART RX 10
and I’m trying to make it work with Gateway-OS.
I made these settings on the concentrator:
global.toml
Concentratord configuration.
[concentratord]
log_level=“INFO”
log_to_syslog=false
stats_interval=“30s”
[concentratord.api]
event_bind=“ipc:///tmp/concentratord_event”command_bind=“ipc:///tmp/concentratord_command”
[gateway]
antenna_gain=5
lorawan_public=true
model=“generic_au915_gps”
gateway_id=“b827ebfffe4bf88c”
channels.toml
[gateway.concentrator]
#AU915 Sub Band 1
multi_sf_channels=[
915200000,
915400000,
915600000,
915800000,
916000000,
916200000,
916400000,
916600000,
][gateway.concentrator.lora_std]
frequency=915900000
bandwidth=500000
spreading_factor=8
band.toml
[gateway.beacon]
compulsory_rfu_size=2
frequencies=[
924500000,
bandwidth=500000
spreading_factor=12
tx_power=14
the gateway appears on the web page, but no lorawam packet is sent
I try to send Join and this error appears in the concentrator
