I can see that there is a max frame log history counter in ns.toml that controls frame history on device’s Lorawan Frames screen in Application Server. But I couldn’t see a similar variable for device’s Device Data screen in Application Server. Is there any option to control it ?
If not I can help to develop it.
taken from configuration page on the NS documentation:
# Device frame-log max history.
# When set to a value > 0, ChirpStack Network Server will log all uplink and
# downlink frames associated to a device as a Redis stream for the
# consumption by external applications (e.g. for monitoring purposes) Note
# that only uplinks passing the MIC and frame-counter tests will be published.
# The configured value will be used as approximate amount of frames which
# will be kept in the stream.
# The following Redis key is used:
# 'lora:ns:device:stream:frame'
device_frame_log_max_history=0
# Per device frame-log max history.
# Equal to the device_frame_log_max_history, but it has the device DevEUI
# in the Redis key. This feature is used by the ChirpStack Application Server
# web-interface.
per_device_frame_log_max_history=10
# Gateway frame-log max history.
# downlink frames received by the gateways as a Redis stream for the
# consumption by external applications (e.g. for monitoring purposes). Note
# that all data reported by the gateways will be published.
# 'lora:ns:gw:stream:frame'
gateway_frame_log_max_history=0
# Per gateway frame-log max history.
# Equal to the gateway_frame_log_max_history, but it has the GatewayID
# web-interface.
per_gateway_frame_log_max_history=10
