So the supplier of the gateway that I’m using gave me a list of channels and frequencies that the gateway listens/transmits to. There are a total of 16 channels as follows:
My gateway-bridge.toml ended up like the following:
[[backend.basic_station.concentrators]]
[backend.basic_station.concentrators.multi_sf]
frequencies=[
923200000,
923400000,
923000000,
922000000,
922200000,
922400000,
922600000,
922800000,
920400000,
920600000,
920800000,
921000000,
921200000,
921400000,
921600000,
921800000,
[backend.basic_station.concentrators.lora_std]
frequency=923200000
bandwidth=125000
spreading_factor=7
[backend.basic_station.concentrators.fsk]
frequency=921800000
Then I added them as extra channels inside the network server configuration, except for the two default frequencies, 923.2MHz and 923.4MHz for the AS923 region. And to my understanding, for the enabled_uplink_channels, I only need to specify the region default channels, which are 0 and 1, instead of 0-15:
enabled_uplink_channels=[0, 1]
frequency=922200000
min_dr=0
max_dr=5
frequency=922400000
min_dr=0
max_dr=5
frequency=922600000
min_dr=0
max_dr=5
frequency=922800000
min_dr=0
max_dr=5
frequency=923000000
min_dr=0
max_dr=5
frequency=922000000
min_dr=0
max_dr=5
frequency=921800000
min_dr=0
max_dr=5
frequency=921000000
min_dr=0
max_dr=5
frequency=920400000
min_dr=0
max_dr=5
frequency=920600000
min_dr=0
max_dr=5
frequency=920800000
min_dr=0
max_dr=5
frequency=921200000
min_dr=0
max_dr=5
frequency=921400000
min_dr=0
max_dr=5
frequency=921600000
min_dr=0
max_dr=5
I restarted my gateway bridge service to load the new configuration and it failed to start. Giving me the following errors:
Feb 24 08:29:47 ip-172-31-13-190 chirpstack-gateway-bridge[32227]: time="2022-02-24T08:29:47.225193806Z" level=fatal msg="setup backend error: new backend error: get router config error: get radio frequencies error: channel 922400000 does not fit in radio bandwidth"
Feb 24 08:29:47 ip-172-31-13-190 systemd[1]: chirpstack-gateway-bridge.service: Main process exited, code=exited, status=1/FAILURE
Feb 24 08:29:47 ip-172-31-13-190 systemd[1]: chirpstack-gateway-bridge.service: Failed with result 'exit-code'.
Feb 24 08:29:47 ip-172-31-13-190 systemd[1]: chirpstack-gateway-bridge.service: Service hold-off time over, scheduling restart.
Feb 24 08:29:47 ip-172-31-13-190 systemd[1]: chirpstack-gateway-bridge.service: Scheduled restart job, restart counter is at 5.
Feb 24 08:29:47 ip-172-31-13-190 systemd[1]: Stopped ChirpStack Gateway Bridge.
Feb 24 08:29:47 ip-172-31-13-190 systemd[1]: chirpstack-gateway-bridge.service: Start request repeated too quickly.
Feb 24 08:29:47 ip-172-31-13-190 systemd[1]: Failed to start ChirpStack Gateway Bridge.
Does anyone knows what am I supposed to do correctly here? I’d appreciate the help
Thanks.
