Hi there,
I use NodeRED to send messages to a Kuando LED. After upgrading to 4.11.0, the first message is received and the LED illuminated to the colour I want. Any further messages are queued and not sent. The messages are marked as not pending. I send messages with a non-confirmed flag too.
This code has worked for months and months.
I guess something has changed?
Can someone help?
Hi, I just updated today from v4.9.0 to v4.11 and I have noticed the same problem.
I can also see that my device only logs one RX-slot after the first TX transmissions, this is not seen before!?
update: I reverted back to 4.9 and it works again.
I might be mistaken on the device logging, I can se the same behavior on 4.9, but when there is a downlink payload it logs it correct.
Hi @Dave, how do you run your gateway?
Packet forward UDP or MQTT, or?
Hi @tomas
I’m using a Multitech AP gateway with the Chirpstack MQTT forwarder installed, sending data to an embedded linux box (Siemens IOT2050) with Chirpstack 4.11.
Hope that helps - Dave
I removed Chirpstack v4.11.0, then went back to Chirpstack v 4.10.1, soon as chirpstack was started everything worked again.
Hey there, have you checked your redis server version?
We had problems that we gut duplicated downlink frame-counter on our devices and no response packets were visible in the web-ui - upgrading redis to a version of 7.4.1 (ubuntu server) solved our issue.
See also our initial report: Downlink Frame Counter (application) not increasing · Issue #605 · chirpstack/chirpstack · GitHub
And the issue that brought us to our solution: Issue with Duplicate Packets on Different Frequencies After Upgrading to v4.11.0 - #6 by landinger
Upgrade redis-server 6.2.3 or above!
Hi all - All working again!
I’ve taken your advice and upgraded REDIS. I used the simple instructions here: Install Redis on Linux | Docs
I’ve upgraded from 6.0.16 to 7.4.1.
All my class-c messages are being processed as before.
HTH
Dave
Hey All,
I ended up here after a 4.11 update that stopped my downlinks as well and found @Dave link. Sadly Redis had broken it since then by moving it to archive on their website.
The new link is Install Redis on Linux
In case they break the link again these are the commands I had to run to upgrade redits from 6.0.16 to 7.4.2 on Ubuntu 22.04
sudo apt-get install lsb-release curl gpg
curl -fsSL https://packages.redis.io/gpg | sudo gpg --dearmor -o /usr/share/keyrings/redis-archive-keyring.gpg
sudo chmod 644 /usr/share/keyrings/redis-archive-keyring.gpg
echo "deb [signed-by=/usr/share/keyrings/redis-archive-keyring.gpg] https://packages.redis.io/deb $(lsb_release -cs) main" | sudo tee /etc/apt/sources.list.d/redis.list
sudo apt-get update
sudo apt-get install redis
You guys rock, I’ve been tearing my hair out on this and it’s fixed the problem. Current redis version is 8.01 and working. Thank you.
