Hello, I am performing a trial of ChirpStack and found the FUOTA feature interesting. I tried to setup a FUOTA session for one device and it is getting stuck on the Multicast setup step.
On the device side, I confirmed that the multicast setup message is received and processed.
Then, the response is sent by the end device back to the server. See the last few lines of the log above, and then the event viewer in Chirpstack of the device below, showing the uplink.
From what I can tell, the downlink is processed and the multicast setup ans response looks correct.
I looked through the syslog output and i don’t see anything standing out.
If it matters, the device is using the 2.4 GHz region and is in class C mode.
I believe the device profile is correctly configured (everything else seems to be working fine) and the profiles match between the device and futoa session.
The device is running the latest version of Semtech LBM on a sx1280 dev board.
Also, an unrelated question, is there a way to stop a FUOTA session other than simply deleting the session?
