Hi, If using a NGINX proxy I can not see events or LoRaWAN frames on the Chirpstack web-interface. Is the reason perhaps a wrong WebSocket configuration? The following configuration example worked perfectly with version 3:
https://www.chirpstack.io/application-server/install/nginx/
server {
listen 443 ssl;
server_name localhost;
ssl_certificate /etc/chirpstack-application-server/certs/http.pem;
ssl_certificate_key /etc/chirpstack-application-server/certs/http-key.pem;
# WebSocket configuration
location ~ ^/api/(gateways|devices)/(\w+)/(frames|events)$ {
proxy_pass http://localhost:8080/api/$1/$2/$3;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "Upgrade";
proxy_read_timeout 86400s;
proxy_send_timeout 86400s;
location / {
proxy_pass http://localhost:8080/;
Does this configuration need to be changed to see the LoRaWAN live frames with Chirpstack 4? If yes, I would grateful for a working config example.
