Chirpstack-API Module
hi,
i try to do some python script against the api. but i fail when i try to import the chirpstack_api module:
script:
import grpc
from  chirpstack_api import api
following error:
  File "/usr/local/lib/python3.8/site-packages/chirpstack_api/api/__init__.py", line 9, in <module>
    from .frame_log_pb2 import *
ModuleNotFoundError: No module named 'chirpstack_api.api.frame_log_pb2'
does anyone know what i am dooing wrong?
Have you installed the package?
pip install chirpstack-api
yes, i did this… we can also see this
# pip list
Package                  Version
<--snip-->
chirpstack-api           4.8.1
Possibly your github issue as well but it seems someone else has a similar issue: Python example (downlink_enqueue.py) fails with chirpstack-api 4.8.1 · Issue #422 · chirpstack/chirpstack · GitHub. Perhaps this is a bug with 8.3.1?
hi, thanks for your answer…
this is maybe a but with version 4.8.1
i uninstaller version 4.8.1 and installed version 4.7 - with this version, there is no error.
let’s see what happend with the issue 422 you posted.
thanks
@brocaar incase this wasn’t on your radar already.
It was already fixed, see: Python example (downlink_enqueue.py) fails with chirpstack-api 4.8.1 · Issue #422 · chirpstack/chirpstack · GitHub
Ah, thank you for your quick work
