I have followed the Quickstart Azure integration. In the chirpstack-network-server.toml
configuration example, it suggests the following settings:
[network_server.gateway.backend]
type="azure_iot_hub"
[network_server.gateway.backend.azure_iot_hub]
events_connection_string="[Gateway Events Connection String]"
commands_connection_string="[Gateway Commands Connection String]"
However when I look at my unedited chirpstack-network-server.toml
the same setting is currently set as follows:
# Backend
type="mqtt"
# MQTT gateway backend settings.
# This is the backend communicating with the LoRa gateways over a MQTT broker.
# MQTT topic templates for the different MQTT topics.
# The meaning of these topics are documented at:
# https://www.chirpstack.io/gateway-bridge/
# The default values match the default expected configuration of the
# ChirpStack Gateway Bridge MQTT backend. Therefore only change these values when
# absolutely needed.
Now this may be a silly ask but I am confused here, do I actually replace type="mqtt"
with type="azure_iot_hub"
or must the Azure related settings be additional to the pre-existing settings? I am quite new to this and currently trying to deploy this as a PoC.
Thank you.
