I have set up a chirpstack gateway bridge for connecting to my MQTT server. That’s work fine but I have a problem with the logging. All logs are written into the syslog. In the chirpstack-gateway-bridge.toml file I have set the log_level=2 and log_to_syslog=false
Any idea why that not work?
Here the .toml file
# This configuration provides a Semtech UDP packet-forwarder backend and
# integrates with a MQTT broker. Many options and defaults have been omitted
# for simplicity.
# See https://www.chirpstack.io/gateway-bridge/install/config/ for a full
# configuration example and documentation.
[general]
log_level=2
log_to_syslog=false
[backend]
# Backend type.
type="semtech_udp"
# Semtech UDP packet-forwarder backend.
[backend.semtech_udp]
# ip:port to bind the UDP listener to
# Example: 0.0.0.0:1700 to listen on port 1700 for all network interfaces.
# This is the listener to which the packet-forwarder forwards its data
# so make sure the 'serv_port_up' and 'serv_port_down' from your
# packet-forwarder matches this port.
udp_bind = "127.0.0.1:1700"
# Integration configuration.
[integration]
# Payload marshaler.
# This defines how the MQTT payloads are encoded. Valid options are:
# * protobuf: Protobuf encoding
# * json: JSON encoding (easier for debugging, but less compact than 'protobuf')
#marshaler="protobuf"
marshaler="json"
# MQTT integration configuration.
[integration.mqtt]
# Event topic template.
event_topic_template="my_lora_gateway/{{ .GatewayID }}/event/{{ .EventType }}"
# Command topic template.
command_topic_template="my_lora_gateway/{{ .GatewayID }}/command/#"
# MQTT authentication.
[integration.mqtt.auth]
# Type defines the MQTT authentication type to use.
# Set this to the name of one of the sections below.
type="generic"
# Generic MQTT authentication.
server="tcp://192.168.42.31:1883"
username="<user>"
password="<pw>"
Norbert
