Hello!
We’ve got a problem with the GatewayOS. We use a IC-880A concentrator board. The reset pin is connected to pin 13 on the concentrator and pin 22 on the raspberry pi.
In the configuration settings we choose this board and pin 22.
Now when executing a $ sudo monit summary
We get this result:
chirpstack-concentratord │ Initializing
The other processes have an OK.
From the logs we read:
Jun 29 08:34:37 raspberrypi3 user.err monit[471]: ‘chirpstack-concentratord’ process is not running
Jun 29 08:34:37 raspberrypi3 user.info monit[471]: ‘chirpstack-concentratord’ trying to restart
Jun 29 08:34:37 raspberrypi3 user.info monit[471]: ‘chirpstack-concentratord’ start: ‘/etc/init.d/chirpstack-concentratord start’
Jun 29 08:34:38 raspberrypi3 user.info chirpstack-concentratord-sx1301[853]: Starting Concentratord SX1301 (version: 3.0.0-test.9, docs: https://www.chirpstack.io/concentratord/)
Jun 29 08:34:38 raspberrypi3 user.info chirpstack-concentratord-sx1301[853]: Setting spi device path, spidev_path: /dev/spidev0.0
Jun 29 08:34:38 raspberrypi3 user.info chirpstack-concentratord-sx1301[853]: Setting board configuration, lorawan_public: true, clock_source: 1
Jun 29 08:34:38 raspberrypi3 user.info chirpstack-concentratord-sx1301[853]: Setting up concentrator radios
Jun 29 08:34:38 raspberrypi3 user.info chirpstack-concentratord-sx1301[853]: Configuring radio, radio: 0, enabled: true, center_freq: 867500000, type: SX1257
Jun 29 08:34:38 raspberrypi3 user.info chirpstack-concentratord-sx1301[853]: Configuring radio, radio: 1, enabled: true, center_freq: 868500000, type: SX1257
Jun 29 08:34:38 raspberrypi3 user.info chirpstack-concentratord-sx1301[853]: Setting up concentrator channels
Jun 29 08:34:38 raspberrypi3 user.info chirpstack-concentratord-sx1301[853]: Configuring multi-SF LoRa channel, channel: 0, enabled: true, freq: 868100000, rf_chain: 1, if_freq: -400000
Jun 29 08:34:38 raspberrypi3 user.info chirpstack-concentratord-sx1301[853]: Configuring multi-SF LoRa channel, channel: 1, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000
Jun 29 08:34:38 raspberrypi3 user.info chirpstack-concentratord-sx1301[853]: Configuring multi-SF LoRa channel, channel: 2, enabled: true, freq: 868500000, rf_chain: 1, if_freq: 0
Jun 29 08:34:38 raspberrypi3 user.info chirpstack-concentratord-sx1301[853]: Configuring multi-SF LoRa channel, channel: 3, enabled: true, freq: 867100000, rf_chain: 0, if_freq: -400000
Jun 29 08:34:38 raspberrypi3 user.info chirpstack-concentratord-sx1301[853]: Configuring multi-SF LoRa channel, channel: 4, enabled: true, freq: 867300000, rf_chain: 0, if_freq: -200000
Jun 29 08:34:38 raspberrypi3 user.info chirpstack-concentratord-sx1301[853]: Configuring multi-SF LoRa channel, channel: 5, enabled: true, freq: 867500000, rf_chain: 0, if_freq: 0
Jun 29 08:34:38 raspberrypi3 user.info chirpstack-concentratord-sx1301[853]: Configuring multi-SF LoRa channel, channel: 6, enabled: true, freq: 867700000, rf_chain: 0, if_freq: 200000
Jun 29 08:34:38 raspberrypi3 user.info chirpstack-concentratord-sx1301[853]: Configuring multi-SF LoRa channel, channel: 7, enabled: true, freq: 867900000, rf_chain: 0, if_freq: 400000
Jun 29 08:34:38 raspberrypi3 user.info chirpstack-concentratord-sx1301[853]: Configuring Std LoRa channel, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000
Jun 29 08:34:38 raspberrypi3 user.info chirpstack-concentratord-sx1301[853]: Configuring FSK channel, enabled: true, freq: 868800000, rf_chain: 1, if_freq: 300000
Jun 29 08:34:38 raspberrypi3 user.info chirpstack-concentratord-sx1301[853]: Starting the the concentrator
Jun 29 08:34:40 raspberrypi3 user.err chirpstack-gateway-bridge[378]: time=“2020-06-29T08:34:40Z” level=error msg=“backend/concentratord: event socket dial error” error="dial event api url error: zmq4: could not dial to “ipc:///tmp/concentratord_event”: dial unix /tmp/co
Jun 29 08:34:43 raspberrypi3 user.err chirpstack-gateway-bridge[378]: time=“2020-06-29T08:34:43Z” level=error msg=“backend/concentratord: event socket dial error” error="dial event api url error: zmq4: could not dial to “ipc:///tmp/concentratord_event”: dial unix /tmp/co
Jun 29 08:34:47 raspberrypi3 user.err chirpstack-gateway-bridge[378]: time=“2020-06-29T08:34:47Z” level=error msg=“backend/concentratord: event socket dial error” error="dial event api url error: zmq4: could not dial to “ipc:///tmp/concentratord_event”: dial unix /tmp/co
Jun 29 08:34:50 raspberrypi3 user.err chirpstack-gateway-bridge[378]: time=“2020-06-29T08:34:50Z” level=error msg=“backend/concentratord: event socket dial error” error="dial event api url error: zmq4: could not dial to “ipc:///tmp/concentratord_event”: dial unix /tmp/co
Jun 29 08:34:54 raspberrypi3 user.err chirpstack-gateway-bridge[378]: time=“2020-06-29T08:34:54Z” level=error msg=“backend/concentratord: event socket dial error” error="dial event api url error: zmq4: could not dial to “ipc:///tmp/concentratord_event”: dial unix /tmp/co
Jun 29 08:34:57 raspberrypi3 user.err chirpstack-gateway-bridge[378]: time=“2020-06-29T08:34:57Z” level=error msg=“backend/concentratord: event socket dial error” error="dial event api url error: zmq4: could not dial to “ipc:///tmp/concentratord_event”: dial unix /tmp/co
Jun 29 08:35:01 raspberrypi3 user.err chirpstack-gateway-bridge[378]: time=“2020-06-29T08:35:01Z” level=error msg=“backend/concentratord: event socket dial error” error="dial event api url error: zmq4: could not dial to “ipc:///tmp/concentratord_event”: dial unix /tmp/co
In which we read that the radio is configured correctly but something else is going on.
Could anybody please help find out what’s happening here? We once had the gateway OS running on this exact pi. We had a problem like this and then it was the reset pin.
But I ran the wires a couple of times and the reset wire IS connected to pin 22.
Thanks in advance,
