Hi all,
I’m wondering what the main difference between the Custom JavaScript codec functions that Chripstack uses versus TTN.
Currently testing an NEXELEC Insafe CO2 sensor on the TTN platform. Nexelec supplies a custom TTN Javascript that I’ve tested and works well.
They however have not tested with Chirpstack.
I would like to test the same type of sensors on Chirpstack - could someone have a look at the attached code and see if it would be possible to modify it slightly to work with Chirpstack?
Thanks in advance…
function Decoder(bytes) {
var hex2=[];
var decode=[];
var string_bin="";
var tab_bin=[];
var string_bin_elements="";
var buffer=[];
var i=0;
var j=0;
// Mise en forme de la payload propre à TTN
for(i=0;i<bytes.length;i++){ // conversion d'hexa à binaire de tous les bytes puis regroupement sous un seul string
string_bin_elements=bytes[i].toString(2);
if(string_bin_elements.length<8){ // PadStart
var nb_zeros=8-string_bin_elements.length;
for (j=0;j<nb_zeros;j++){
string_bin_elements="0"+string_bin_elements;
string_bin=string_bin+string_bin_elements;
var compte=0;
for(i=0;i<2*bytes.length;i++){
buffer[i]="";
for( j=0;j<4;j++){ // tableau contenant un hexa de la payload par adresse
buffer[i]=buffer[i]+string_bin.charAt(compte);
compte++;
buffer[i]=parseInt(buffer[i],2);
// Décodage
var Insafe_Carbon_LoRa=0x7;
switch(buffer[0]){
case Insafe_Carbon_LoRa:
decode[0]={"Type_of_Product":"Insafe_Carbon_LoRa"};
break;
if (buffer[0]==Insafe_Carbon_LoRa){
// On crée les différents tableaux correspondant à la taille de chaque data en terme de bits
var tab_decodage_Real_Time=[4,4,8,8,8,3,4,3,3,3,3,2,3]; // Exemple: la 2ème information donc [1] est codée sur 4 bits
var tab_decodage_Product_Status_Message=[4,4,2,1,3,2,8,8,6,4,5,5,6,6];
var tab_decodage_Push=[4,4,3,3,2];
var tab_decodage_Datalog=[4,4,8,8,8,8,8,8,8,8,8,4,3,1];
var tab_decodage_Temperature_Alert=[4,4,8,1,1,3,3];
var tab_decodage_CO2_Alert=[4,4,8,3,1,1,3];
var tab_decodage_Config_CO2=[4,4,8,8,6,6,6,6,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,8];
var tab_decodage_Config_General=[4,4,1,1,1,1,1,1,1,1,8,8,8,8,8,8,8,8,2,6];
var tab_decodage_Keepalive=[4,4];
// On initialise les différents type de message pour les Carbon
var Type_Real_Time= 0x2;
var Type_Product_Status_Message=0x3;
var Type_Push= 0x4;
var Type_Datalog=0x5;
var Type_Temperature_Alert=0x6;
var Type_CO2_Alert=0x7;
var Type_Config_CO2=0x8;
var Type_Config_General=0x9;
var Type_Keep_Alive=0xA;
//Tous les indicateurs sont codés de la même manière pour coder plus efficacement on crée un tableau
// qui contient tous ces adjectifs
var tab_adjectif=["Excellent","Good","Fair","Poor","Bad","Erreur","All","Dryness Indicator","Mould Indicator","Dust Mites Indicator","CO","CO2"];
// Avec buffer[1], on détermine le Type de Message
switch(buffer[1]){
case Type_Real_Time:
tab_decode(tab_decodage_Real_Time); //(VOIR EN FIN DE PROGRAMME) On passe le tableau correspondant au message dans la fonction tab_decode, cette fonction renvoie tab_bin.
decode[1]={"Type_of_message":"Real_Time"};
decode[2]={"CO2_concentration_(ppm)": 20*tab_bin[2]};
decode[3]={"Temperature(°C)": Math.round(0.2*tab_bin[3] * 10) / 10};
decode[4]={"Relative_Humidity_(%RH)": 0.5*tab_bin[4]};
decode[5]={"IAQ_GLOBAL":get_iaq(tab_bin[5])};
decode[6]={"IAQ_SRC":get_iaq_SRC(tab_bin[6])};
decode[7]={"IAQ_CO2":get_iaq(tab_bin[7])};
decode[8]={"IAQ_DRY":get_iaq(tab_bin[8])};
decode[9]={"IAQ_MOULD":get_iaq(tab_bin[9])};
decode[10]={"IAQ_DM":get_iaq(tab_bin[10])};
decode[11]={"IAQ_HCI":get_IAQ_HCI(tab_bin[11])};
decode[12]={"Frame_Index":tab_bin[12]};
break;
case Type_Product_Status_Message:
tab_decode(tab_decodage_Product_Status_Message);
decode[1]={"Type_of_message":"Product_Status_Message"};
decode[2]={"Battery_level":battery(tab_bin[2])};
decode[3]={"HW_Fault_mode":hw_mode(tab_bin[3])};
decode[4]={"Frame_Index":tab_bin[4]};
decode[5]={"Not_used":""};
decode[6]={"Product_hours_meter(per month)":tab_bin[6]};
decode[7]={"CO2_autocalibration_value_(ppm)": 20*tab_bin[7]};
decode[8]={"Product_RTC_date_since_2000 (in years)": tab_bin[8]};
decode[9]={"Product_RTC_date__Month_of_the_year":tab_bin[9]};
decode[10]={"Product_RTC_date__Day_of_the_month":tab_bin[10]};
decode[11]={"Product_RTC_date_Hours_of_the_day":tab_bin[11]};
decode[12]={"Product_RTC_date__Minutes_of_the_hour":tab_bin[12]};
decode[13]={"Not_used":""};
break;
case Type_Push:
tab_decode(tab_decodage_Push);
decode[1]={"Type_of_message":"Push"};
decode[2]={"Push_Button_Action": push_button(tab_bin[2])};
decode[3]={"Frame_Index":tab_bin[3]};
decode[4]={"Not_used":""}
break;
case Type_Datalog:
tab_decode(tab_decodage_Datalog);
decode[1]={"Type_of_message":"Datalog"};
decode[2]={"CO2_concentration(ppm)_[n-2]": 20*tab_bin[2]};
decode[3]={"Temperature(°C) [n-2]": Math.round(0.2*tab_bin[3] * 10) / 10};
decode[4]={"Relative Humidity(%) [n-2]": 0.5*tab_bin[4]};
decode[5]={"CO2_concentration(ppm)_[n-1]": 20*tab_bin[5]};
decode[6]={"Temperature(°C) [n-1]": Math.round(0.2*tab_bin[6] * 10) / 10};
decode[7]={"Relative Humidity(%) [n-1]": 0.5*tab_bin[7]};
decode[8]={"CO2_concentration(ppm) [n]": 20*tab_bin[8]};
decode[9]={"Temperature(°C) [n]": Math.round(0.2*tab_bin[9] * 10) / 10};
decode[10]={"Relative Humidity(%) [n]": 0.5*tab_bin[10]};
decode[11]={"Time_between_measurements_in_minutes": 10*tab_bin[11]};
break;
case Type_Temperature_Alert:
tab_decode(tab_decodage_Temperature_Alert);
decode[1]={"Type_of_message":"Temperature_Alert"};
decode[2]={"Temperature(°C)": Math.round(0.2*tab_bin[2] * 10) / 10};
decode[3]={"Temperature threshold 1":th(tab_bin[3])};
decode[4]={"Temperature threshold 2":th(tab_bin[4])};
decode[5]={"Frame_Index":tab_bin[5]};
decode[6]={"Not_used":""};
break;
case Type_CO2_Alert:
tab_decode(tab_decodage_CO2_Alert);
decode[1]={"Type_of_message":"CO2_Alert"};
decode[2]={"CO2_concentration(ppm)": 20*tab_bin[2]};
decode[4]={"CO2_threshold_1":th(tab_bin[4])};
decode[5]={"CO2_threshold_2":th(tab_bin[5])};
break;
case Type_Config_CO2:
tab_decode(tab_decodage_Config_CO2);
decode[1]={"Type_of_message":"Config_CO2"};
decode[2]={"CO2_threshold_1":20*tab_bin[2]};
decode[3]={"CO2_threshold_2":20*tab_bin[3]};
decode[4]={"Smart Period 1 start at: (hour)":0.5*tab_bin[4]};
decode[5]={"Smart Period 1 duration (hour)":0.5*tab_bin[5]};
decode[6]={"Smart Period 2 start at: (hour)":0.5*tab_bin[6]};
decode[7]={"Smart Period 2 duration (hour)":0.5*tab_bin[7]};
decode[8]={"Smart Period 1": active(tab_bin[8])};
decode[9]={"Smart Period 1 on Monday": active(tab_bin[9])};
decode[10]={"Smart Period 1 on Tuesday": active(tab_bin[10])};
decode[11]={"Smart Period 1 on Wednesday": active(tab_bin[11])};
decode[12]={"Smart Period 1 on Thursday": active(tab_bin[12])};
decode[13]={"Smart Period 1 on Friday": active(tab_bin[13])};
decode[14]={"Smart Period 1 on Saturday": active(tab_bin[14])};
decode[15]={"Smart Period 1 on Sunday": active(tab_bin[15])};
decode[16]={"Smart Period 2": active(tab_bin[16])};
decode[17]={"Smart Period 2 on Monday": active(tab_bin[17])};
decode[18]={"Smart Period 2 on Tuesday": active(tab_bin[18])};
decode[19]={"Smart Period 2 on Wednesday": active(tab_bin[19])};
decode[20]={"Smart Period 2 on Thursday": active(tab_bin[20])};
decode[21]={"Smart Period 2 on Friday": active(tab_bin[21])};
decode[22]={"Smart Period 2 on Saturday": active(tab_bin[22])};
decode[23]={"Smart Period 2 on Sunday": active(tab_bin[23])};
decode[24]={"Altitude":50*tab_bin[24]};
break;
case Type_Config_General:
tab_decode(tab_decodage_Config_General);
decode[1]={"Type_of_message":"Config_General"};
decode[2]={"LED blink": active(tab_bin[2])};
decode[3]={"Button Notification": active(tab_bin[3])};
decode[4]={"Real-time data": active(tab_bin[4])};
decode[5]={"Datalog enable": active(tab_bin[5])};
decode[6]={"Temperature Alert": active(tab_bin[6])};
decode[7]={"CO2 Alert": active(tab_bin[7])};
decode[8]={"Keep Alive": active(tab_bin[8])};
decode[9]={"Orange_Led":active(tab_bin[9])};
decode[10]={"Period between measurements (CO2,temperature, humidity) (minutes)": tab_bin[10]};
decode[11]={"Datalog decimation factor(record only 1 on x samples)":tab_bin[11]};
decode[12]={"Temperature alert threshold 1 (°C)": 0.2*tab_bin[12]};
decode[13]={"Temperature alert threshold 2 (°C)": 0.2*tab_bin[13]};
decode[14]={"Temperature change leading to a real-time message transmission (°C)": 0.1*tab_bin[14]};
decode[15]={"Relative humidity change leading to a real-time message transmission (%RH)": 0.5*tab_bin[15]};
decode[16]={"CO2 concentration change leading to a realtime message transmission(ppm)": 20*tab_bin[16]};
decode[17]={"Keepalive period (h)": tab_bin[17]};
decode[18]={"NFC_status":nfc_status(tab_bin[18])};
decode[19]={"Not_Used":""};
break;
case Type_Keep_Alive:
decode[1]={"Type_of_message":"Keep_Alive"};
break;
var new_msg={payload:decode};
return new_msg;
function tab_decode (tab){ // on rentre en paramètre la table propre à chaque message
var compteur=0;
for ( i=0; i<tab.length;i++){ // tab.length nousdonne donc le nombre d'information à décoder pour ce message
tab_bin[i]="";
for ( j=0; j<tab[i];j++){ // tab[i] nous donne le nombre de bits sur lequel est codée l'information i
str1=string_bin.charAt(compteur); // compteur va aller de 0 jusqu'à la longueur de string_bin
tab_bin[i]=tab_bin[i]+str1; // A la fin de ce deuxième for: tab_bin[i] sera composé de tab[i] bits
compteur++;
// Problème si tab[i] bits est différent de 4 (ou 8) bits ca ne correspond à 1 (ou 2) hexa donc: ne pourra pas conrrectement convertir les binaires en hexa
// Donc il faut qu'on fasse un bourrage de 0 grâce à padstart
if (tab_bin[i].length>4){ // pour les données de tailles supérieures à 4 bits et inféireures ou égales à 8 bits
//tab_bin[i]=tab_bin[i].padStart(8,'0');
tab_bin[i]=parseInt(tab_bin[i] , 2).toString(16).toUpperCase(); // Puis on convertit les binaire en hexa (en string)
tab_bin[i]=parseInt(tab_bin[i],16) ;//puis on convertit les string en int
else{ // pour les données de tailles inférieures ou égales à 4 bits
//tab_bin[i]=tab_bin[i].padStart(4,'0');
tab_bin[i]=parseInt(tab_bin[i], 16);
function get_iaq (a){
var result="";
switch(a){
case 0:
result=tab_adjectif[0];
break;
case 1:
result=tab_adjectif[1];
break;
case 2:
result=tab_adjectif[2];
break;
case 3:
result=tab_adjectif[3];
break;
case 4:
result=tab_adjectif[4];
break;
case 5:
result=tab_adjectif[5];
break;
return result;
function get_iaq_SRC(a){
var result="";
switch(a){
case 0:
result=tab_adjectif[6];
break;
case 1:
result=tab_adjectif[7];
break;
case 2:
result=tab_adjectif[8];
break;
case 3:
result=tab_adjectif[9];
break;
case 4:
result=tab_adjectif[10];
break;
case 5:
result=tab_adjectif[11];
break;
case 15:
break;
return result;
function get_IAQ_HCI(a){
var result="";
switch(a){
case 0:
break;
case 1:
break;
case 2:
break;
case 3:
break;
return result;
// C'est la fonction la plus importante du programme
var compteur=0;
tab_bin[i]="";
compteur++
var nb_zeros=8-tab_bin[i].length;
tab_bin[i]="0"+tab_bin[i];
tab_bin[i]=parseInt(tab_bin[i],16) //puis on convertit les string en int
return tab_bin;
function battery(a){
result="";
switch(a){
case 0:
result="High";
break;
case 1:
result="Medium";
break;
case 2:
result="Critical";
break;
return result;
function hw_mode(a){
result="";
switch(a){
case 0:
result=" non activated";
break;
case 1:
result=" activated";
break;
return result;
function push_button(a){
result="";
switch(a){
case 0:
result="Short Push";
break;
case 1:
result="Long Push";
break;
case 2:
result="Multiple Push(x3)";
break;
case 3:
result="Multiple Push(x6)";
break;
return result;
function th(a){
result="";
switch(a){
case 0:
result="not reached";
break;
case 1:
result="reached";
break;
return result;
function active(a){
result="";
switch(a){
case 0:
result="Non-Active";
break;
case 1:
result="Active";
return result;
function nfc_status(a)
result="";
switch(a){
case 0:
result="Discoverable";
break;
case 1:
result="Not_Discoverable";
return result;
msg.payload=decode;
return msg;
