Chirpstack Docker Mqtt
Hi everyone,
I’m trying to get certificate in order to use MQTT integration.
Following the step in the link below for docker I stop on the first command , that is:
MQTT_BROKER_HOSTS=127.0.0.1,localhost,mqtt.example.com
CHIRPSTACK_GATEWAY_BRIDGE_HOSTS=127.0.0.1,localhost,cgwb.example.com
make set-hosts.
I don’t understand the command above, are 3 command in sequence or only one? Chirpstack is running correctly but the command above in the prompt is not working, maybe I need some extra work in the config file, seevices or anything else.
Thank you for your help
Paolo
It is a single command, broken up in different lines. See the README of the repository:
docker-compose run --rm \
    -e MQTT_BROKER_HOSTS="localhost,mqtt.example.com" \
    -e CHIRPSTACK_GATEWAY_BRIDGE_HOSTS="localhost,cgwb.example.com" \
    chirpstack-certificates make set-hosts
Thank you Brocaar, now I figure out how ot works
