I have just installed chirpstack application server, network server and gateway bridge on my raspberry pi. I have stand-alone gateways from rak wireless which are configured as a packet forwarder.
I created all the gateway profile, service profile, device profile and added gateway which is connected and then added a device.
Device is trying to join with OTAA but never gets accept from chirpstack. i see join request but no Accept in live lora frames.
I can see in network server logs that it is accepted, but the downlink is not being sent
May 10 14:48:03 homeserver chirpstack-gateway-bridge[7011]: time="2022-05-10T14:48:03.474572721+02:00" level=info msg="integration/mqtt: publishing event" event=up qos=0 topic=gateway/ac1f09fffe06052e/event/up uplink_id=c4701c9c-b255-4755-8b85-8364d32a4ef3
May 10 14:48:03 homeserver chirpstack-network-server[6983]: time="2022-05-10T14:48:03.478072447+02:00" level=info msg="gateway/mqtt: uplink frame received" gateway_id=ac1f09fffe06052e uplink_id=c4701c9c-b255-4755-8b85-8364d32a4ef3
May 10 14:48:03 homeserver chirpstack-network-server[6983]: time="2022-05-10T14:48:03.682621129+02:00" level=info msg="uplink: frame(s) collected" ctx_id=f2995206-1ede-4834-aea8-f407563f831a mtype=JoinRequest uplink_ids="[c4701c9c-b255-4755-8b85-8364d32a4ef3]"
May 10 14:48:03 homeserver chirpstack-application-server[6998]: time="2022-05-10T14:48:03.696496922+02:00" level=info msg="backend/joinserver: request received" message_type=JoinReq receiver_id=b827ebfffe390000 sender_id=000000 transaction_id=2801051666
May 10 14:48:03 homeserver chirpstack-application-server[6998]: time="2022-05-10T14:48:03.703331355+02:00" level=info msg="device-keys updated" ctx_id="<nil>" dev_eui=ac1f09fffe064035
May 10 14:48:03 homeserver chirpstack-application-server[6998]: time="2022-05-10T14:48:03.703608299+02:00" level=info msg="backend/joinserver: sending response" dev_eui=ac1f09fffe064035 message_type=JoinAns receiver_id=000000 result_code=Success sender_id=b827ebfffe390000 transaction_id=2801051666
May 10 14:48:03 homeserver chirpstack-network-server[6983]: time="2022-05-10T14:48:03.704670961+02:00" level=info msg="lorawan/backend: finished backend api call" message_type=JoinReq protocol_version=1.0 receiver_id=b827ebfffe390000 result_code=Success sender_id=000000 transaction_id=2801051666
May 10 14:48:03 homeserver chirpstack-network-server[6983]: time="2022-05-10T14:48:03.705082811+02:00" level=info msg="sent uplink meta-data to network-controller" ctx_id=f2995206-1ede-4834-aea8-f407563f831a dev_eui=ac1f09fffe064035
May 10 14:48:03 homeserver chirpstack-network-server[6983]: time="2022-05-10T14:48:03.707104154+02:00" level=info msg="device-queue flushed" ctx_id=f2995206-1ede-4834-aea8-f407563f831a dev_eui=ac1f09fffe064035
May 10 14:48:03 homeserver chirpstack-network-server[6983]: time="2022-05-10T14:48:03.708573611+02:00" level=info msg="device-session saved" ctx_id=f2995206-1ede-4834-aea8-f407563f831a dev_addr=01cde36d dev_eui=ac1f09fffe064035
May 10 14:48:03 homeserver chirpstack-network-server[6983]: time="2022-05-10T14:48:03.713262368+02:00" level=info msg="device-activation created" ctx_id=f2995206-1ede-4834-aea8-f407563f831a dev_eui=ac1f09fffe064035 id=8
May 10 14:48:03 homeserver chirpstack-network-server[6983]: time="2022-05-10T14:48:03.717600054+02:00" level=info msg="device updated" ctx_id=f2995206-1ede-4834-aea8-f407563f831a dev_eui=ac1f09fffe064035
May 10 14:48:03 homeserver chirpstack-network-server[6983]: time="2022-05-10T14:48:03.718197329+02:00" level=info msg="gateway/mqtt: publishing gateway command" command=down downlink_id=f2995206-1ede-4834-aea8-f407563f831a gateway_id=ac1f09fffe06052e qos=0 topic=gateway/ac1f09fffe06052e/command/down
May 10 14:48:03 homeserver chirpstack-gateway-bridge[7011]: time="2022-05-10T14:48:03.719572286+02:00" level=info msg="integration/mqtt: downlink frame received" downlink_id=f2995206-1ede-4834-aea8-f407563f831a gateway_id=ac1f09fffe06052e
May 10 14:48:03 homeserver chirpstack-network-server[6983]: time="2022-05-10T14:48:03.720670318+02:00" level=info msg="storage: downlink-frame saved" ctx_id=f2995206-1ede-4834-aea8-f407563f831a token=63722
Anybody have any idea what could be wrong?
keys are correct.
My gateway is 3 meters away so in range. and also It was working before, but my SD card on RPI died so I did all the install from scratch. And now (maybe new version of chirpstack) it is not working.
Thank you very much for a help.
