Hi everyone,
For my project at the university, i’ll try to setup an FUOTA enviroment.
I have a RAK831-Rapberry Pi gateway running the Gateway OS base on IP 192.168.1.111.
Then I have an Ubunut 20 host machine with static IP 192.168.1.112 running docker.
I have successfully installed the normal Chirpstack network server and applications server (Quickstart Docker Compose - ChirpStack open-source LoRaWAN<sup>®</sup> Network Server). I was also able to connect the gateway and receive data from a node.
Now I wanted to install the chirpstack-fuota-server https://github.com/brocaar/chirpstack-fuota-server in parallel to finally divide nodes into a multicast group and send data with the fragmented data block transfer protocol.
I have done all the steps described in the README.
The docker-container ruinning are:
If I now start the chirpstack-fuota-server following error occurs:
bash-5.1# chirpstack-fuota-server
INFO[0000] starting ChirpStack FUOTA Server version=
INFO[0000] storage: connecting to PostgreSQL database
WARN[0000] storage: ping PostgreSQL database error, will retry in 2s error="dial tcp 127.0.0.1:5432: connect: connection refused"
WARN[0002] storage: ping PostgreSQL database error, will retry in 2s error="dial tcp 127.0.0.1:5432: connect: connection refused"
WARN[0004] storage: ping PostgreSQL database error, will retry in 2s error="dial tcp 127.0.0.1:5432: connect: connection refused"
WARN[0006] storage: ping PostgreSQL database error, will retry in 2s error="dial tcp 127.0.0.1:5432: connect: connection refused"
WARN[0008] storage: ping PostgreSQL database error, will retry in 2s error="dial tcp 127.0.0.1:5432: connect: connection refused"
WARN[0010] storage: ping PostgreSQL database error, will retry in 2s error="dial tcp 127.0.0.1:5432: connect: connection refused"
WARN[0012] storage: ping PostgreSQL database error, will retry in 2s error="dial tcp 127.0.0.1:5432: connect: connection refused"
WARN[0014] storage: ping PostgreSQL database error, will retry in 2s error="dial tcp 127.0.0.1:5432: connect: connection refused"
WARN[0016] storage: ping PostgreSQL database error, will retry in 2s error="dial tcp 127.0.0.1:5432: connect: connection refused"
WARN[0018] storage: ping PostgreSQL database error, will retry in 2s error="dial tcp 127.0.0.1:5432: connect: connection refused"
WARN[0020] storage: ping PostgreSQL database error, will retry in 2s error="dial tcp 127.0.0.1:5432: connect: connection refused"
WARN[0022] storage: ping PostgreSQL database error, will retry in 2s error="dial tcp 127.0.0.1:5432: connect: connection refused"
WARN[0024] storage: ping PostgreSQL database error, will retry in 2s error="dial tcp 127.0.0.1:5432: connect: connection refused"
WARN[0026] storage: ping PostgreSQL database error, will retry in 2s error="dial tcp 127.0.0.1:5432: connect: connection refused"
Does anyone have an idea how to run the normal chirpstack-network-server in parallel with the chirpstack-fuota-server and using the same gateway and application server?
Big thanks
Corsin
