Hello ChirpStack Community,
I’m trying to set up FUOTA using the ChirpStack FUOTA server, but I’m facing an issue with the PostgreSQL connection. Here’s what I’ve done so far:
- Successfully built the LoRaWAN_FUOTA project from the stm32cube_wl_fw_v1.3.0 library provided by STMicroelectronics.
- Installed the ChirpStack FUOTA server from the GitHub repository and ran it using Docker. The containers seem to start properly:
sudo docker compose up -d
[+] Running 3/3
✔ Network chirpstack-fuota-server_default Created
✔ Container chirpstack-fuota-server-postgres-1 Started
✔ Container chirpstack-fuota-server-chirpstack-fuota-server-1 Started
However, when I run the main.go script for the fuota deployment, it gets stuck after downloading dependencies:
go: downloading golang.org/x/text v0.3.3
Checking the FUOTA server container logs shows the following error repeatedly:
chirpstack-fuota-server-1 | time="2025-03-25T05:12:02Z" level=warning msg="storage: ping PostgreSQL database error, will retry in 2s" error="dial tcp [::1]:5432: connect: connection refused"
chirpstack-fuota-server-1 | time="2025-03-25T05:12:04Z" level=warning msg="storage: ping PostgreSQL database error, will retry in 2s" error="dial tcp [::1]:5432: connect: connection refused"
chirpstack-fuota-server-1 | time="2025-03-25T05:12:06Z" level=warning msg="storage: ping PostgreSQL database error, will retry in 2s" error="dial tcp [::1]:5432: connect: connection refused"
chirpstack-fuota-server-1 | time="2025-03-25T05:12:08Z" level=warning msg="storage: ping PostgreSQL database error, will retry in 2s" error="dial tcp [::1]:5432: connect: connection refused"
chirpstack-fuota-server-1 | time="2025-03-25T05:12:10Z" level=warning msg="storage: ping PostgreSQL database error, will retry in 2s" error="dial tcp [::1]:5432: connect: connection refused"
chirpstack-fuota-server-1 | time="2025-03-25T05:12:12Z" level=warning msg="storage: ping PostgreSQL database error, will retry in 2s" error="dial tcp [::1]:5432: connect: connection refused"
chirpstack-fuota-server-1 | time="2025-03-25T05:12:14Z" level=warning msg="storage: ping PostgreSQL database error, will retry in 2s" error="dial tcp [::1]:5432: connect: connection refused"
chirpstack-fuota-server-1 | time="2025-03-25T05:12:16Z" level=warning msg="storage: ping PostgreSQL database error, will retry in 2s" error="dial tcp [::1]:5432: connect: connection refused"
chirpstack-fuota-server-1 | time="2025-03-25T05:12:18Z" level=warning msg="storage: ping PostgreSQL database error, will retry in 2s" error="dial tcp [::1]:5432: connect: connection refused"
chirpstack-fuota-server-1 | time="2025-03-25T05:12:20Z" level=warning msg="storage: ping PostgreSQL database error, will retry in 2s" error="dial tcp [::1]:5432: connect: connection refused"
I verified that the PostgreSQL container is running, but the FUOTA server still fails to connect.
Has anyone faced a similar issue or can provide guidance on resolving this? I’d appreciate any help or pointers to get this working.
Thank you!
Best regards,
Pratham
