This is my setup with RAK7371 WisGate Developer Base connected with USB to a RaspberryPi4B
chirpstack-gateway-bridge
cat docker-compose.yml
version: '3.6' networks: loranet: external: true services: chirpstack-gateway-bridge: image: chirpstack/chirpstack-gateway-bridge:3.14.0 container_name: gatewaybridge hostname: gatewaybridge restart: always logging: options: max-size: "10m" max-file: "3" ports: - "1700:1700/udp" volumes: - ./chirpstack-gateway-bridge.toml:/etc/chirpstack-gateway-bridge/chirpstack-gateway-bridge.toml networks: loranet:
udp-packet-forwarder
version: '3.6' networks: loranet: external: true services: udp-packet-forwarder: image: rakwireless/udp-packet-forwarder:v1.1.3 container_name: udpforwarder hostname: udpforwarder restart: always logging: options: max-size: "10m" max-file: "3" privileged: true volumes: - ./global_conf.json:/app/global_conf.json:ro environment: MODEL: "RAK7371" MODULE: "RAK5146" CONCENTRATOR: "SX1303" HAS_GPS: "0" INTERFACE: "USB" GATEWAY_EUI: "26E804FFFE7093C0" SERVER_HOST: "gatewaybridge.loranet" SERVER_PORT: "1700" RADIO_DEV: "/dev/ttyACM0" GATEWAY_EUI_NIC: "usb0" BAND: "us_902_928" networks: loranet:
RabbitMQ mqtt plugin is enabled, where I see the connection established from chirpstack-gateway-bridge container. A queue is created mqtt-subscription-66C0A7FC63D30000qos0 which confirms successful creation of all the containers and the connection between chirpstack-gateway-bridge and rabbitmq is working.
But when I send data from lora devices I do not see any data received by chirpstack-gateway-bridge or rabbitmq.
Is there any documentation to how to setup wis developer gateway with chirpstack-gateway-bridge and store data to RabbitMQ?
