Good day,
I have a problem where my gateway-bridge** where there are errors initially then it connects to the the UDP and MQTT in an unstable way** as seen below:
Here is the actual terminal results:
ubuntu@ip-172-31-41-91 : ~ $ journalctl -u chirpstack-gateway-bridge -f -n 50
– Logs begin at Wed 2020-11-18 23:22:05 UTC. –
Nov 19 00:12:04 ip-172-31-41-91 chirpstack-gateway-bridge[2868]: time=“2020-11-19T00:12:04Z” level=error msg=“integration/mqtt: connection error” error=“Network Error : dial tcp 127.0.0.1:1883: connect: connection refused”
Nov 19 00:12:06 ip-172-31-41-91 chirpstack-gateway-bridge[2868]: time=“2020-11-19T00:12:06Z” level=error msg=“integration/mqtt: connection error” error=“Network Error : dial tcp 127.0.0.1:1883: connect: connection refused”
Nov 19 00:12:08 ip-172-31-41-91 chirpstack-gateway-bridge[2868]: time=“2020-11-19T00:12:08Z” level=error msg=“integration/mqtt: connection error” error=“Network Error : dial tcp 127.0.0.1:1883: connect: connection refused”
Nov 19 00:12:10 ip-172-31-41-91 chirpstack-gateway-bridge[2868]: time=“2020-11-19T00:12:10Z” level=error msg=“integration/mqtt: connection error” error=“Network Error : dial tcp 127.0.0.1:1883: connect: connection refused”
Nov 19 00:13:10 ip-172-31-41-91 chirpstack-gateway-bridge[2868]: time=“2020-11-19T00:13:10Z” level=info msg=“integration/mqtt: connected to mqtt broker”
Nov 19 00:14:03 ip-172-31-41-91 systemd[1]: Stopping ChirpStack Gateway Bridge…
Nov 19 00:14:03 ip-172-31-41-91 chirpstack-gateway-bridge[2868]: time=“2020-11-19T00:14:03Z” level=info msg=“signal received” signal=terminated
Nov 19 00:14:03 ip-172-31-41-91 chirpstack-gateway-bridge[2868]: time=“2020-11-19T00:14:03Z” level=warning msg=“shutting down server”
Nov 19 00:14:03 ip-172-31-41-91 systemd[1]: Stopped ChirpStack Gateway Bridge.
Nov 19 00:14:03 ip-172-31-41-91 systemd[1]: Started ChirpStack Gateway Bridge.
Nov 19 00:14:04 ip-172-31-41-91 chirpstack-gateway-bridge[17796]: time=“2020-11-19T00:14:04Z” level=info msg=“starting ChirpStack Gateway Bridge” docs=“Introduction - ChirpStack open-source LoRaWAN<sup>®</sup> Network Server” version=3.9.2
Nov 19 00:14:04 ip-172-31-41-91 chirpstack-gateway-bridge[17796]: time=“2020-11-19T00:14:04Z” level=info msg=“backend/semtechudp: starting gateway udp listener” addr=“0.0.0.0:1700”
Nov 19 00:14:04 ip-172-31-41-91 chirpstack-gateway-bridge[17796]: time=“2020-11-19T00:14:04Z” level=info msg=“integration/mqtt: connected to mqtt broker”
> Nov 20 00:30:48 ip-172-31-41-91 systemd[1]: Stopping ChirpStack Gateway Bridge…
Nov 20 00:30:48 ip-172-31-41-91 chirpstack-gateway-bridge[17796]: time=“2020-11-20T00:30:48Z” level=info msg=“signal received” signal=terminated
Nov 20 00:30:48 ip-172-31-41-91 chirpstack-gateway-bridge[17796]: time=“2020-11-20T00:30:48Z” level=warning msg=“shutting down server”
Nov 20 00:30:48 ip-172-31-41-91 systemd[1]: Stopped ChirpStack Gateway Bridge.
Nov 20 00:30:48 ip-172-31-41-91 systemd[1]: Started ChirpStack Gateway Bridge.
Nov 20 00:30:48 ip-172-31-41-91 chirpstack-gateway-bridge[15781]: time=“2020-11-20T00:30:48Z” level=info msg=“starting ChirpStack Gateway Bridge” docs=“Introduction - ChirpStack open-source LoRaWAN<sup>®</sup> Network Server” version=3.9.2
Nov 20 00:30:48 ip-172-31-41-91 chirpstack-gateway-bridge[15781]: time=“2020-11-20T00:30:48Z” level=info msg=“backend/semtechudp: starting gateway udp listener” addr=“0.0.0.0:1700”
Nov 20 00:30:48 ip-172-31-41-91 chirpstack-gateway-bridge[15781]: time=“2020-11-20T00:30:48Z” level=info msg=“integration/mqtt: connected to mqtt broker”
My main problem could be I have the wrong config file (.toml), do you think that is the problem?
Notes: I followed the tutorial here
ANY AND ALL HELP IS APPRECIATED
and it is in sync so that is not the problem.
