after installing the package (chirpstack-gateway-bridge_3.10.0-r1_mips_24kc.ipk) and adapting the toml file, the service is started via
/etc/init.d/chirpstack-gateway-bridge start
as described. The process then also runs with a high load, but does not open any ports. There are also no messages in the log.
Also the start by hand
/opt/chirpstack-gateway-bridge/chirpstack-gateway-bridge -h
does not produce any output and only causes high processor load (75…98%).
I just reflashed the LG308 because it had the same effect with the older firmware. The version now is lgw-5.4.1610176959 / Build Sat Jan 9 15:22:39 CST 2021 .
Does anyone know the problem and a solution?
