i have an installation of 4.1.1, which works fine, however, when i install 4.2.0, i get the following boot screen, and it seems to hang forever. (the black screen)
Hardware is raspberry pi 3B+, can you think of anything that would cause this to happen on my end?
edit: i also tried with a new sdcard, as well as a raspberry pi 4 and it seemed to work… which made me re-check my DHCP leases, and for some reason, its got a different IP with a different SDcard, when the same hardware, which surprised me.
Depending on what you were doing, you may be able to access the RPi via its hostname, rather than IP address. Raspbian has the Avahi Daemon installed, so multicast DNS can be used.
