Hello everyone, is it possible to run CS GatewayOS inside a Docker container? It should be possible to access the SPI with --privileged flag: (Running containers | Docker Docs). I use a WM1302 on pi hat as interface.
Thank you for your time and patience in replying here.
Please note that the ChirpStack Gateway OS is an OpenWrt based OS. This is not something that you can run within Docker. You could however run some of the ChirpStack software within Docker. E.g. you might be able to run the ChirpStack Concentratord within Docker. However, I do not have any examples for you.
