Using a known good SD card, I have tried multiple times to load the Gateway OS Full image onto a RPi 3B and it fails to boot. Just get blinking red LED. This card is good, because I can load other RPi OS images on it and they work. Have tried a different RPi, no luck. Tried a different power supply, no luck. Tried different tools to create the image, no luck. What am i missing? Any help would be appreciated.
I apologize, but I was not waiting long enough for the boot process. It does boot Ok. You can close this topic.
You can mark your own answer as Solution, there is a button next to the bottom buttons
That will close the post automatically I think.
What steps did you take to ensure successful booting? Could you describe the process and the format in which you flashed the image? I am getting an error while booting the base image on my Raspberry Pi Zero W.
Please help!
what are the errors?
I solved this issue by flashing another upgraded version[ 4.1.1] of chirpstack gateway os.
Thank you for reply!
