I was trying to build the gateway OS and I could not get past this error:
Steps followed:
- git clone https://github.com/brocaar/chirpstack-gateway-os.git
- cd chirpstack-gateway-os
- make submodules
- make permissions
- source oe-init-build-env build bitbake
- bitbake chirpstack-gateway-os-base
The build failed at following task:
chirpstack-concentratord_3.0.2.bb:do_compile
Below is the detail build log for your reference. May I request to help me resolve this?
| Running rustc --crate-name async_trait --edition=2018 /home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/cargo_home/registry/src/github.com-1ecc6299db9ec823/async-trait-0.1.24/src/lib.rs --error-format=json --json=diagnostic-rendered-ansi --crate-type proc-macro --emit=dep-info,link -C prefer-dynamic -C opt-level=3 -Cembed-bitcode=no -C debuginfo=2 -C metadata=6c5a76feb53889c2 -C extra-filename=-6c5a76feb53889c2 --out-dir /home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/target/release/deps -C linker=/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/wrappers/linker-native-wrapper.sh -L dependency=/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/target/release/deps --extern proc_macro2=/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/target/release/deps/libproc_macro2-517717b2eeea032e.rlib --extern quote=/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/target/release/deps/libquote-80f3914f530d27d8.rlib --extern syn=/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/target/release/deps/libsyn-12b9455517cbcce0.rlib --extern proc_macro --cap-lints allow
| Running rustc --crate-name serde_derive /home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/cargo_home/registry/src/github.com-1ecc6299db9ec823/serde_derive-1.0.104/src/lib.rs --error-format=json --json=diagnostic-rendered-ansi --crate-type proc-macro --emit=dep-info,link -C prefer-dynamic -C opt-level=3 -Cembed-bitcode=no -C debuginfo=2 --cfg 'feature="default"' -C metadata=cde67fa097453f12 -C extra-filename=-cde67fa097453f12 --out-dir /home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/target/release/deps -C linker=/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/wrappers/linker-native-wrapper.sh -L dependency=/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/target/release/deps --extern proc_macro2=/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/target/release/deps/libproc_macro2-517717b2eeea032e.rlib --extern quote=/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/target/release/deps/libquote-80f3914f530d27d8.rlib --extern syn=/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/target/release/deps/libsyn-12b9455517cbcce0.rlib --extern proc_macro --cap-lints allow
| Compiling rand v0.7.3
| Compiling simple_logger v1.5.0
| Running rustc --crate-name rand --edition=2018 /home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/cargo_home/registry/src/github.com-1ecc6299db9ec823/rand-0.7.3/src/lib.rs --error-format=json --json=diagnostic-rendered-ansi,artifacts --crate-type lib --emit=dep-info,metadata,link -C opt-level=3 -Cembed-bitcode=no -C debuginfo=2 --cfg 'feature="alloc"' --cfg 'feature="default"' --cfg 'feature="getrandom"' --cfg 'feature="getrandom_package"' --cfg 'feature="libc"' --cfg 'feature="std"' -C metadata=889bc72257887270 -C extra-filename=-889bc72257887270 --out-dir /home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/target/armv7-unknown-linux-gnueabihf/release/deps --target armv7-unknown-linux-gnueabihf -C linker=/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/wrappers/linker-wrapper.sh -L dependency=/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/target/armv7-unknown-linux-gnueabihf/release/deps -L dependency=/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/target/release/deps --extern getrandom_package=/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/target/armv7-unknown-linux-gnueabihf/release/deps/libgetrandom-2591183458f44a4f.rmeta --extern libc=/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/target/armv7-unknown-linux-gnueabihf/release/deps/liblibc-e8a1de2073893db9.rmeta --extern rand_chacha=/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/target/armv7-unknown-linux-gnueabihf/release/deps/librand_chacha-45e16364f51a5282.rmeta --extern rand_core=/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/target/armv7-unknown-linux-gnueabihf/release/deps/librand_core-ec4794005c662fe2.rmeta --cap-lints allow
| Running rustc --crate-name simple_logger /home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/cargo_home/registry/src/github.com-1ecc6299db9ec823/simple_logger-1.5.0/src/lib.rs --error-format=json --json=diagnostic-rendered-ansi --crate-type lib --emit=dep-info,metadata,link -C opt-level=3 -Cembed-bitcode=no -C debuginfo=2 --cfg 'feature="chrono"' --cfg 'feature="colored"' --cfg 'feature="default"' -C metadata=a907341d199030e9 -C extra-filename=-a907341d199030e9 --out-dir /home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/target/armv7-unknown-linux-gnueabihf/release/deps --target armv7-unknown-linux-gnueabihf -C linker=/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/wrappers/linker-wrapper.sh -L dependency=/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/target/armv7-unknown-linux-gnueabihf/release/deps -L dependency=/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/target/release/deps --extern chrono=/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/target/armv7-unknown-linux-gnueabihf/release/deps/libchrono-da23d2684eb9d7f2.rmeta --extern colored=/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/target/armv7-unknown-linux-gnueabihf/release/deps/libcolored-4903e3bd1a8e9b31.rmeta --extern log=/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/target/armv7-unknown-linux-gnueabihf/release/deps/liblog-245b42fd488bc8eb.rmeta --cap-lints allow
| The following warnings were emitted during compilation:
| warning: gcc: error: unrecognized command line option ‘-fmacro-prefix-map=/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1=/usr/src/debug/chirpstack-concentratord/3.0.2-r1’
| error: failed to run custom build command for libloading v0.5.2
| Caused by:
| process didn’t exit successfully: /home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/target/release/build/libloading-cb7b018aa809cc7e/build-script-build
(exit code: 1)
| — stdout
| cargo:rustc-link-lib=dl
| TARGET = Some(“x86_64-unknown-linux-gnu”)
| OPT_LEVEL = Some(“3”)
| HOST = Some(“x86_64-unknown-linux-gnu”)
| CC_x86_64-unknown-linux-gnu = None
| CC_x86_64_unknown_linux_gnu = None
| HOST_CC = None
| CC = Some("/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/wrappers/cc-native-wrapper.sh")
| CFLAGS_x86_64-unknown-linux-gnu = None
| CFLAGS_x86_64_unknown_linux_gnu = None
| HOST_CFLAGS = None
| CFLAGS = Some(" -O2 -pipe -g -feliminate-unused-debug-types -fmacro-prefix-map=/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1=/usr/src/debug/chirpstack-concentratord/3.0.2-r1 -fdebug-prefix-map=/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1=/usr/src/debug/chirpstack-concentratord/3.0.2-r1 -fdebug-prefix-map=/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/recipe-sysroot= -fdebug-prefix-map=/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/recipe-sysroot-native= ")
| CRATE_CC_NO_DEFAULTS = None
| DEBUG = Some(“true”)
| CARGO_CFG_TARGET_FEATURE = Some(“fxsr,sse,sse2”)
| running: “/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/wrappers/cc-native-wrapper.sh” “-O3” “-ffunction-sections” “-fdata-sections” “-fPIC” “-g” “-fno-omit-frame-pointer” “-m64” “-O2” “-pipe” “-g” “-feliminate-unused-debug-types” “-fmacro-prefix-map=/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1=/usr/src/debug/chirpstack-concentratord/3.0.2-r1” “-fdebug-prefix-map=/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1=/usr/src/debug/chirpstack-concentratord/3.0.2-r1” “-fdebug-prefix-map=/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/recipe-sysroot=” “-fdebug-prefix-map=/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/recipe-sysroot-native=” “-o” “/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/target/release/build/libloading-8b4570a569a949e1/out/src/os/unix/global_static.o” “-c” “src/os/unix/global_static.c”
| cargo:warning=gcc: error: unrecognized command line option ‘-fmacro-prefix-map=/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1=/usr/src/debug/chirpstack-concentratord/3.0.2-r1’
| exit code: 1
| — stderr
| error occurred: Command “/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/wrappers/cc-native-wrapper.sh” “-O3” “-ffunction-sections” “-fdata-sections” “-fPIC” “-g” “-fno-omit-frame-pointer” “-m64” “-O2” “-pipe” “-g” “-feliminate-unused-debug-types” “-fmacro-prefix-map=/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1=/usr/src/debug/chirpstack-concentratord/3.0.2-r1” “-fdebug-prefix-map=/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1=/usr/src/debug/chirpstack-concentratord/3.0.2-r1” “-fdebug-prefix-map=/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/recipe-sysroot=” “-fdebug-prefix-map=/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/recipe-sysroot-native=” “-o” “/home/ravi/chirpstack-gateway-os/build/tmp/raspberrypi/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/chirpstack-concentratord/3.0.2-r1/target/release/build/libloading-8b4570a569a949e1/out/src/os/unix/global_static.o” “-c” “src/os/unix/global_static.c” with args “cc-native-wrapper.sh” did not execute successfully (status code exit code: 1).
| warning: build failed, waiting for other jobs to finish…
| error: build failed
| WARNING: exit code 101 from a shell command.
ERROR: Task (/home/ravi/chirpstack-gateway-os/layers/chirpstack/meta-chirpstack/recipes-chirpstack/chirpstack-concentratord/chirpstack-concentratord_3.0.2.bb:do_compile) failed with exit code ‘1’
NOTE: Tasks Summary: Attempted 3494 tasks of which 3493 didn’t need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
