Hello ChirpStack Support Team, I have installed and configured ChirpStack gateway-os-base properly on Raspberry Pi as per ChirpStack Gateway OS documentation, but getting Never Seen error issue for the Gateway at ChirpStack network server. Could you please assist further to fix this issue? Attached are the setup screenshots to be reviewed by you for this. Thanks.
You probably want to point your MQTT Forwarder configuration to a non-localhost hostname. E.g. replace this with the hostname of your ChirpStack server.
Hello @brocaar, Thank you for your valuable help. After pointing both MQTT forwarder and UDP forwarder configuration with the hostname of my ChirpStack server it fixed the issue. Thanks.
Hello @kpin404 how you configured the chirpstack Gateway after installing OS-base ? i installed Gateway OS -base verison 4.1.1 , configured it by using sudo gateway-config command , and reviewed status using sudo monit summary command in terminal but iam getting same never seen issue at chirpstack server end ?
please help!
Hello shreyavadla, I have configured Chirpstack GW OS-base through its web config page. Thanks.
