Chirpstack http integration not working
Does the http integration not work to https URL’s? The error I’m seeing is very vague so I’m not sure why it’s failing.
2024-07-02T15:16:19.140056Z WARN chirpstack::integration::http: Posting event failed event=up url=https://redacted:28088/services/collector/raw error=error sending request for url (https://redacted:28088/services/collector/raw?event=up)
The https urls do work.
Did you try to send data to your endpoint, for instance with curl, from the same machine?
Try sending to a public url (i really like https://webhook.site for this purpose - it’ll generate a custom URL for you to watch your posts).
If this doesn’t work, then it’s an integration issue, if it does work, then it’s probably with whatever server you’re sending to.
Yep, I tried it to pastebin the other day and it worked just fine so I know the integration itself is working, I just can’t figure out why the integration isn’t working when sending data to cribl, even though if I do it as a curl from the server it works just fine.
Yes, sorry I meant to put that in my post, I did do a curl -k and it worked just fine.
So if I log into the server and do a curl with the following format:
curl -k “https://cribl-prd.(redacted.com):28088/services/collector/raw”
-H “Authorization: (redacted)”
-d ‘{“event”: “test data 1”}{“event”: “test data 2”}’
I see data coming into splunk. However, if I configure the integration with:
Payload encoding = JSON
URL: https://cribl-prd.(redacted.com):28088/services/collector/raw
Header
Authorization : (redacted HEC token)
Nothing shows up.
