I am trying to install Chirpstack server on Raspberry Pi 3 , Raspbian GNU/Linux 11 (bullseye) using this manual: Docker - ChirpStack open-source LoRaWAN® Network Server documentation, and this Stage 2: Install and Configure the ChirpStack Network Server: Install ChirpStack Locally, but after some minutes the installation process is frozen on string
chirpstack-1 | 2024-04-05T15:53:51.915070Z INFO chirpstack::gateway::backend::mqtt: Subscribing to gateway event topic region_id=eu433 event_topic=$share/chirpstack/eu433/gateway/+/event/+
I did the same some times and using 3 Raspberry Pi3, but the result is the same.
How can I do the installation?
Thank you!
