Hello everybody,
I have a question about your LoRa project Chirpstack.io.
I am using the Image Gateway OS Full on a Raspberry Pi 3B+ and am trying to connect my IoT devices to Azure. I saw the integration with Azure Service Hub, but I would like to use the Gateway OS Full and run all coponents of the LoRa Stack on the Raspberry Pi. My aim is to receive messages that my gateway/network server receives, in the Azure IoT Hub and forward them for example wit a stream analytics job in azure. There I came across a problem. The messages that are sent to the IoT hub are in Protobuf format. Then I wanted to write a deserializer, but there is no implementation for C# in the API.
Another idea was, to configure the JSON-Format in the chirpstack bridge, but then the Payload is unencodable in Azure.
Can you help me there?
Kind regards,
Alex
