Chirpstack network server repository
Can someone give me the current URL for the latest version. The one in the documentation isn’t working.
Thanks
all working by this URL https://www.chirpstack.io/network-server/downloads/
Where is the broken link you’re referring to? Just curious, so we can fix it :smile:
John,
I may be doing this all wrong. It’s been around 5 years since I have worked on Linux. I had been working fiber DWDM networking but I am glad to back on Linux.
I started from the network server download page. It appears to me you have 3 options, download binaries, download packages, download repository.
I tried to post but it said new users can only put 2 links in a post.
I have always used repositories so I am trying to take that path. I followed the setup on the download page. I had to erase the steps on the download page due to being a new user
sudo apt-key adv
sudo echo
sudo tee
sudo apt update.
It gets 12 packages 11 from ubuntu and 1 from https://artifacts.chirpstack.io/packages/3.x/deb stable InRelease but although I don’t get an error message the package isn’t installed. If I browse the repository the package isn’t in the URL artifacts.chirpstack…
I hope this is clear and I feel like I was making a mistake. I did get the package installed by downloading the package to my pc then moving it to the server and using dpkg.
Thanks
are you read this chapter? https://www.chirpstack.io/application-server/install/debian/
eugenev,
Yes I have read it many times. I did get the package installed and running by using the download link. I was then able to get it running using the dpkg command.
Thank you
