I am using docker-compose to run up a complete stack with postgres, mosquitto, redis CSAS and CSNS.
I have based the toml files for the CSAS and CSNS from the examples, and have noticed that the binds are different for the docker-compose setup for the API set up on ports 8000 and 8001 from the web site default setup of bind=“0.0.0.0:8000”. I have used the example from the docker-compose yml to use public_host=“chirpstack-network-server:8000” in CSNS toml, and public_host=“chirpstack-application-server:8001” in the CSAS toml. The stack uses several mosquitto brokers, redis, postgres, and all is well with these, all containers are running, and the stack is accessible from localhost:8080 for the GUI and appears to be running OK. I am getting LoRa packets from a connected gateway OK, and the join server is also running on 8003 OK, BUT I am seeing a connection request from the CSNS to 127.0.0.1:8001, a local host address. There is no setup in the toml files for such a connection, as the public_host settings as above have been selected in the toml files, so where is CSNS activating this localhost connection request from?
From docker-compose terminal output :-
chirpstack-network-server | time=“2021-07-06T14:11:54.6025111Z” level=warning msg=“creating insecure application-server client” server=“localhost:8001”
chirpstack-network-server | time=“2021-07-06T14:11:54.6029281Z” level=warning msg="[core] grpc: addrConn.createTransport failed to connect to {localhost:8001 localhost:8001 0 }. Err: connection error: desc = “transport: Error while dialing dial tcp 127.0.0.1:8001: connect: connection refused”. Reconnecting…
From CSAS toml file ;-
