I have just released a ChirpStack Node-RED nodes package, which can be used to received uplinks from ChirpStack (using MQTT) and schedule downlinks using the ChirpStack gRPC API. Instructions on how to use this package can be found here: GitHub - brocaar/node-red-contrib-chirpstack: ChirpStack Node-RED nodes.
which node did you choose to insert the device event? I installed the chirpstack package, but I couldnāt find this node. I need your help please!
It uses the MQTT node, which is already provided by Node-RED. While it is aimed at ChirpStack Gateway OS uses, this might be helpful: Node-RED quickstart - ChirpStack open-source LoRaWAN<sup>Ā®</sup> Network Server.
So from what I understand, I have to install the geteway OS on my gateway first?
Not my take: you just need to install THIS add-on to integrate with ChirpStack into your existing Node-RED. MQTT node comes with Node-RED already but you do need to configure it to subscribe to your ChirpStack.
Iām trying to install this without too much luck. But I had to upgrade a lot of Node-RED modules (last did that 3 yrs ago
) so Iām a little behind the times.
Had to put in ticket for IT to retire Win7 virtual server and spin me up a Win10 version. Oops.
for the configuration of MQTT with chirpstack I did this
For the installation I followed the link you gave me, and it gave me these nodes
But I canāt find here the device event node
:pensive
These are not the nodes provided by GitHub - chirpstack/node-red-contrib-chirpstack: ChirpStack Node-RED nodes ā¦
@brocaar, so I was about to post that I got same result as @Nabila only to realize my mistake: I had previously used Node-RED palette to install a package thatās available from their repository (thatās what the blue nodes are) called chirpstack (lower case) while your nodes are āChirpStackā (mixed case) installed using npm:
Here are both packages:
Easiest way to see whatās going on is to go to top-right of Node-RED UI, click on āhamburgerā and select Manage Palette:
bruh i still dont understand how you manage to install the non-blue shirpstack nodes.im using the npm installer to only get errors
Can you post errors youāre getting?
I can tell you that I first had to get a newer Node.js (which required a newer version of Windows; newest Node.js didnāt support Windows 7) and then I installed most recent nodeRED and everything else was pretty smooth after that, except for what I said about chirpstack vs ChirpStack.
Iāve installed new updated chirpstack node-red nodes https://github.com/brocaar/node-red-contrib-chirpstack but canāt make it running?! I did it some time ago, prior update , fallowing the instructions and it was running properly. Now I get enqueue error as shown on the figure.
How can I troubleshoot this error?
Is there any missing instruction for this new updated nodes?
I wander why is changed DevEUI to DevEui?!
best regards,
Nenad
This was version issue! I was using newly published V4.0.0 chirpstack up/downlink nodes with prev version of chirpstack network and app servers.
When installed @chirpstack/node-red-contrib-chirpstack@3.0.1 both, up and downlink messages work smoothly as before.
Anyhow Iām still curious to know how to troubleshoot enqueue error (and other type of errors) when happens.
can you send the contrib v3 installation tutorial?
Thereās no any special tutorial, you should fallow https://github.com/brocaar/node-red-contrib-chirpstack, just force installation of 3.0.1 version with
npm install @chirpstack/node-red-contrib-chirpstack@3.0.1
and be sure that you properly deleted previously installed version.
Check it with npm list -g if you install it as global
If you still see old version in palette manager do restart Node-red. I use pm2 for that. br
Hi @nensak ,
what version of node.js and node-red are you using? I already forced the installation with npm install @chirpstack/node-red-contrib-chirpstack@3.0.1 , restarted node-red, and I still do not see any of the ChirpStack nodes available. When I search on the āManage Paletteā section, I only see the nodes available from @smartparks but nothing from @chirpstack.
Thank you!
I have solved it after many restarts of node-red.
cd ~/.node-redlscd node_modulesgit clone https://github.com/brocaar/node-red-contrib-chirpstack.gitnpm i node-red-contrib-chirpstacknode-red restart- Close web session
- Reopen. They should appear after restarting node-red.
Make sure you have Node-Red version 3.0.1 and stable version of node.js, which is v16.16.0 as of now.
the āecho functionā examples above and throughout the documentation make sense as the foundation for a class A device but Iām looking to initiate downlinks on an ad-hoc basis for a (timing insensitive) Class C device which necessitates constructing the downlink message without the aid of an inbound message. Iāve had this working previously but am now screwing it up somehow, as the downlink node reports an error ādevEui is undefinedā.
Iām constructing the input in a function node in the form:
msg.payload = {
devEui: āa840535318187faā,
confirmed: false,
fPort: 4,
data: ā08ffā,
return msg;
Can anyone point to an example function node that does work?
using ChirpStack 4.01
So Iāve upgraded to 4.0.2 and downlinks are now working with no change to the function node code.
But i still get [different] unexpected output from the downlink node:
msg : undefined
undefined
Should this not be returning the downlink ID? I can see that in other respects the downlink is definitely working.
I wander if anyone managed to make downlink working in node-red-contrib-chirpstack@4.0.0?!
I did it with version @3.0.1 and with chiprstack V3 but now I canāt repeat it again.
On @4.0.0 I could not make it at all, as I suppose that @4.0.0 must be used with chirpstack V4, and canāt run with V3?
I saw that porzim posted an issue on github and have got an attention of brocar, so I hope this will be solved soon.
I just want to stress that I keep this as very important element of entire chirpstack infrastructure. When looking on TTN there are many resources related to using Node Red in many scenarios. We are lacking any progress in this topic. SSome real example would be of great help if anyone can help?
