Chirpstack not publishing to Mosquitto after successful connection
I’ve installed chirpstack onto an RPi4.
The devices are registering successfully onto the network/application, and i can see the events and frames appearing on the chirpstack web interface.
I have a standalone gateway (Laird) which is forwarding the Semtech UDP packets ok, via the chirpstack-gateway-bridge.
The chirpstack-gateway-bridge is publishing status messages successfully onto the Mosquitto broker that is also hosted on the RPi.
The application however is not posting any messages onto the “application/#” topic.
Its almost like the integration is not up or something, however i’ve checked the startup logs and it says it successfully connects to the MQTT server…
Here’s the configuration snippet from chirpstack.toml
#Enabled integrations (global).
enabled = [
#MQTT integration configuration.
[integration.mqtt]
# Event topic template.
event_topic="application/{{application_id}}/device/{{dev_eui}}/event/{{event}}"
# Command topic.
# This is the topic on which the MQTT subscribes for receiving (enqueue) commands.
command_topic="application/{{application_id}}/device/{{dev_eui}}/command/{{command}}"
# Use JSON encoding instead of Protobuf (binary).
json=true
server="tcp://localhost:1883/"
username=""
password=""
# Quality of service level
# 0: at most once
# 1: at least once
# 2: exactly once
qos=0
# Clean session
clean_session=false
# Client ID
# broker. A client id must be no longer than 23 characters. If left blank,
# a random id will be generated by ChirpStack.
client_id=""
# Keep alive interval.
# This defines the maximum time that that should pass without communication
# between the client and server.
keep_alive_interval="30s"
ca_cert=""
tls_cert=""
# TLS key file (optional)
tls_key=""
Happy to post the entire config if anyone can help.
It looks like you didn’t enable the MQTT integration. Chirpstack does use MQTT for communicating with the Gateway Bridge component, and that might have been the connection successful message that you saw.
enabled = [
"mqtt"
Thanks, sp193.
I think that was it.
Pretty sure I didn’t read that anywhere in the doco.
I am new to the LoRaWan game, so something else that was catching me out, was that my devices were on like half hour uplink times. So even after watching the logs for ten minutes i was just not seeing them on appear on the application/# topic.
I ended up using MQTT explorer which displayed all the different topics on the broker.
