Hi All,
For testing purposes I would like to install an environment similar to what I would get via chirpstack-docker installation (ie chirpstack, chirpstack-gateway-bridge, postgres, redis and mosquitto) on a system with few resources ( ARM 64-bit 4-Core CPU - 1,5GB of RAM - 60GB HD).
This system will manages a small amount of devices (circa 15-30) and one gateway only.
Anyone has ever test this kind of solution?
According with your experience, Could chirpstack run with this resources?
Thank you so much,
If I well understood postgres is used for storing configuration data, so component that requires more RAM may be redis. It it correct?
That should be fine I believe. Iām running my test environment on a $5 DigitalOcean droplet. If you are storing the data on the server as well, then you will see an increase of data over time, but for 15-30 devices this is not so much.
For example, if each device sends data once an hour, then that equals to ~ 1 message per 2 minutes.
