ChirpStack OS 4.3.1 to 4.5.2 Update Fails
The update from ChirpStack OS 4.3.1 to 4.5.2 fails on my RAK7248 using a RAK2287 shield. I can access the OpenWrt web interface, but the ChirpStack web interface fails to load. The restore.sh command also generated errors (see below).
Steps:
  1. Currently running ChirpStack 4.8 with tenant, API keys, device profiles applications…
  2. Backup Postgres and Redis databases per Changelog instructions: WRT console System > Custom Commands
  3. Download the new 4.5.2 Sysupgrade image for Raspberry Pi 4B (my RAK7248)
  4. Flash the Sysupgrade image using OpenWrt web interface
  5. Run the ChirpStack Restore command
  6. Using OpenWrt web interface, manually enable the Concentratord and MQTT Forwarder after restoring the databases.
restore.sh errors:
‘/opt/chirpstack/restore.sh’
Restore PostgreSQL database
Restore Redis database
pg_restore: error: could not execute query: ERROR: cannot drop constraint tenant_pkey on table public.tenant because other objects depend on it
DETAIL: constraint relay_gateway_tenant_id_fkey on table public.relay_gateway depends on index public.tenant_pkey
HINT: Use DROP … CASCADE to drop the dependent objects too.
Command was: ALTER TABLE ONLY public.tenant DROP CONSTRAINT tenant_pkey;
pg_restore: error: could not execute query: ERROR: cannot drop table public.tenant because other objects depend on it
DETAIL: constraint relay_gateway_tenant_id_fkey on table public.relay_gateway depends on table public.tenant
Command was: DROP TABLE public.tenant;
pg_restore: error: could not execute query: ERROR: relation “tenant” already exists
Command was: CREATE TABLE public.tenant (
id uuid NOT NULL,
created_at timestamp with time zone NOT NULL,
updated_at timestamp with time zone NOT NULL,
name character varying(100) NOT NULL,
description text NOT NULL,
can_have_gateways boolean NOT NULL,
max_device_count integer NOT NULL,
max_gateway_count integer NOT NULL,
private_gateways_up boolean NOT NULL,
private_gateways_down boolean NOT NULL,
tags jsonb NOT NULL
pg_restore: error: COPY failed for table “tenant”: ERROR: duplicate key value violates unique constraint “tenant_pkey”
DETAIL: Key (id)=(52f14cd4-c6f1-4fbd-8f87-4025e1d49242) already exists.
CONTEXT: COPY tenant, line 1
pg_restore: error: could not execute query: ERROR: multiple primary keys for table “tenant” are not allowed
ADD CONSTRAINT tenant_pkey PRIMARY KEY (id);
pg_restore: warning: errors ignored on restore: 5
ln: /var/lib/redis/redis: File exists
After my upgrade of a RAK7248 from ChirpStack 4.3.1 to 4.5.2 failed, I reverted to ChirpStack 4.2.0 from a backup. An attempt to upgrade from 4.2.0 to the latest 4.5.4 OS also failed. (See related issue “ChirpStack Gateway OS with RAK2287 fails”).
