Chirpstack OS GPS Data overwritten
Hi All,
I have installed Chripstack OS with module SX1303, everything is working but GPS values are overwritten as 0,0 in Server as I don’t have GPS module, so I have 2 solutions :
  • Put manual GPS values but how ?
  • Disable transmission of GPS data but how ?
Can you please help ?
I found myself how to put manual values :
  • edit /etc/chirpstack-concentratord/sx1302/cat region_eu868.toml
  • add at end of the file manual GPS and altitude values like below :
# Static gateway location.
[gateway.location]
# When set to non-zero values, the static gateway location will be reported
# when the gateway does not have a GNSS module or when no GNSS location fix
# is available.
    latitude=48.84207
    longitude=2.32194
    altitude=47
  • reboot the gateway
    Then you will see values in chirpstack server
But I still not found how to stop GPS report values because we can also put manual values in chirpstack server but without stop report from gateway the values are overwritten.
Someone know how to stop GPS report ?
