HI everyone,
I am able to run the whole chirpstack solution on Unix and Redhat however, a particular client is not allwoing to use a unix based OS. So, i am forced to use the chirpstack precomiled windows binaries. and am running into issues.
for example, after i installed the exe through cmd, it gives errors about db authentication.
Has anyone ever been able to setup the whole shirptatck solution on Windows using the windows binarie… Docker is not an option either…
If yes on the above, can someone pointme to a documentation if there is one.
I would really appreciate your advice.
Thanks,
S
