Hi all,
I’m trying to setup a Chirpstack LNS and BasicStation gateway and both of these components are running in NXP i.MX boards. I am facing a connection refused error from BasicStation even if I put the correct IP address and port numbers:
[Note: There will be extra comments from the normal BasicStation logs, as I have included them to root cause the problem]
Here is my gateway-bridge configuration:
# See https://www.chirpstack.io/gateway-bridge/install/config/ for a full
# configuration example and documentation.
servers=["tcp://mosquitto:1883"]
username=""
password=""
[integration.mqtt]
#event_topic_template="ism2400/gateway/{{ .GatewayID }}/event/{{ .EventType }}"
#state_topic_template="ism2400/gateway/{{ .GatewayID }}/state/{{ .StateType }}"
#command_topic_template="ism2400/gateway/{{ .GatewayID }}/command/#"
event_topic_template="eu868/gateway/{{ .GatewayID }}/event/{{ .EventType }}"
state_topic_template="eu868/gateway/{{ .GatewayID }}/state/{{ .StateType }}"
command_topic_template="eu868/gateway/{{ .GatewayID }}/command/#"
#event_topic_template="us915_0/gateway/{{ .GatewayID }}/event/{{ .EventType }}"
#state_topic_template="us915_0/gateway/{{ .GatewayID }}/state/{{ .StateType }}"
#command_topic_template="us915_0/gateway/{{ .GatewayID }}/command/#"
#event_topic_template="us915_1/gateway/{{ .GatewayID }}/event/{{ .EventType }}"
#state_topic_template="us915_1/gateway/{{ .GatewayID }}/state/{{ .StateType }}"
#command_topic_template="us915_1/gateway/{{ .GatewayID }}/command/#"
#event_topic_template="us915_2/gateway/{{ .GatewayID }}/event/{{ .EventType }}"
#state_topic_template="us915_2/gateway/{{ .GatewayID }}/state/{{ .StateType }}"
#command_topic_template="us915_2/gateway/{{ .GatewayID }}/command/#"
#event_topic_template="us915_3/gateway/{{ .GatewayID }}/event/{{ .EventType }}"
#state_topic_template="us915_3/gateway/{{ .GatewayID }}/state/{{ .StateType }}"
#command_topic_template="us915_3/gateway/{{ .GatewayID }}/command/#"
#event_topic_template="us915_4/gateway/{{ .GatewayID }}/event/{{ .EventType }}"
#state_topic_template="us915_4/gateway/{{ .GatewayID }}/state/{{ .StateType }}"
#command_topic_template="us915_4/gateway/{{ .GatewayID }}/command/#"
#event_topic_template="us915_5/gateway/{{ .GatewayID }}/event/{{ .EventType }}"
#state_topic_template="us915_5/gateway/{{ .GatewayID }}/state/{{ .StateType }}"
#command_topic_template="us915_5/gateway/{{ .GatewayID }}/command/#"
#event_topic_template="us915_6/gateway/{{ .GatewayID }}/event/{{ .EventType }}"
#state_topic_template="us915_6/gateway/{{ .GatewayID }}/state/{{ .StateType }}"
#command_topic_template="us915_6/gateway/{{ .GatewayID }}/command/#"
#event_topic_template="us915_7/gateway/{{ .GatewayID }}/event/{{ .EventType }}"
#state_topic_template="us915_7/gateway/{{ .GatewayID }}/state/{{ .StateType }}"
#command_topic_template="us915_7/gateway/{{ .GatewayID }}/command/#"
[backend]
#type="basic_station"
# Basic Station backend.
[backend.basic_station]
# ip:port to bind the Websocket listener to.
bind=":3001"
# TLS certificate and key files.
# When set, the websocket listener will use TLS to secure the connections
# between the gateways and ChirpStack Gateway Bridge (optional).
tls_cert=""
tls_key=""
# TLS CA certificate.
# When configured, ChirpStack Gateway Bridge will validate that the client
# certificate of the gateway has been signed by this CA certificate.
ca_cert=""
# Stats interval.
# This defines the interval in which the ChirpStack Gateway Bridge forwards
# the uplink / downlink statistics.
stats_interval="30s"
# Ping interval.
ping_interval="1m0s"
# Timesync interval.
# This defines the interval in which the ChirpStack Gateway Bridge sends
# a timesync request to the gateway. Setting this to 0 disables sending
# timesync requests.
timesync_interval="1h0m0s"
# Read timeout.
# This interval must be greater than the configured ping interval.
read_timeout="1m5s"
# Write timeout.
write_timeout="1s"
# Region.
# Please refer to the LoRaWAN Regional Parameters specification
# for the complete list of common region names.
region="EU868"
# Minimal frequency (Hz).
frequency_min=863000000
# Maximum frequency (Hz).
frequency_max=870000000
# Concentrator configuration.
# This section contains the configuration for the SX1301 concentrator chips.
# Example:
# [[backend.basic_station.concentrators]]
# # Multi-SF channel configuration.
# [backend.basic_station.concentrators.multi_sf]
# # Frequencies (Hz).
# frequencies=[
# 868100000,
# 868300000,
# 868500000,
# 867100000,
# 867300000,
# 867500000,
# 867700000,
# 867900000,
# # LoRa STD channel.
# [backend.basic_station.concentrators.lora_std]
# # Frequency (Hz).
# frequency=868300000
# # Bandwidth (Hz).
# bandwidth=250000
# # Spreading factor.
# spreading_factor=7
# # FSK channel.
# [backend.basic_station.concentrators.fsk]
# # Frequency (Hz).
# frequency=868800000
Can anyone please point me where I’m going wrong or how to resolve the connection refused error?[Note: I’m trying to connect without any security, so I’m not using any certificates.]
