I need some help configuring the network server for AS_923_4 (i.e. 917-920). This is what I have so far. What else am I missing?
# See https://www.chirpstack.io/network-server/install/config/ for a full
# configuration example and documentation.
# This file is for the AS_923_4 band. See the examples/ folder for more
# configuration examples.
[postgresql]
dsn="postgres://user:password@postgres:5433/lorawan_nsas923_4?sslmode=require"
[redis]
servers=[ "servername1:6378", "servernam2:6378" ]
password="PASSWORD"
# Database index.
# By default, this can be a number between 0-15.
database=0
# Redis Cluster.
# instance.
cluster=false
# Master name.
# Set the master name when the provided URLs are pointing to a Redis Sentinel
# instance.
master_name=""
# Connection pool size.
# Default (when set to 0) is 10 connections per every CPU.
pool_size=0
# TLS enabled.
# Note: this will enable TLS, but it will not validate the certificate
# used by the server.
tls_enabled=true
[network_server]
net_id="009234"
[network_server.band]
name="AS_923_4"
frequency_min=917300000
frequency_max=917500000
enabled_uplink_channels=[1, 2, 3, 4, 5, 6]
server="tcp://mqtt:1883"
# Event topic template.
event_topic="as923_4/gateway/+/event/+"
# Command topic template.
# Use:
# * "{{ .GatewayID }}" as an substitution for the LoRa gateway ID
# * "{{ .CommandType }}" as an substitution for the command type
command_topic_template="as923_4/gateway/{{ .GatewayID }}/command/{{ .CommandType }}"
[join_server.default]
server="http://chirpstack-application-server:8003"
