I have tried a few times to update to latest gateway bridge but I get these errors and cannot upgrade it past 4.0.9 or 4.0.10 I have it on tag version 4 at the moment. Is there anything I can do to fix these errors? the latest gw bridge just seems to fail to pass any uplink or downlink data from helium or private gateways altogether.
chirpstack-docker-chirpstack-1 | 2024-01-12T08:28:56.977789Z INFO chirpstack::gateway::backend::mqtt: Message received from gateway region_id="au915_1" topic="au915_1/gateway/2864afc74baa57f1/event/up" qos=0 json=false
chirpstack-docker-chirpstack-1 | 2024-01-12T08:28:57.180429Z WARN chirpstack::uplink: tx_info of uplink event is empty, skipping
chirpstack-docker-chirpstack-1 | 2024-01-12T08:28:57.180469Z WARN chirpstack::uplink: tx_info of uplink event is empty, skipping
chirpstack-docker-chirpstack-1 | 2024-01-12T08:28:57.180702Z ERROR chirpstack::uplink: Deduplication error error=Unable to get first item from rx_info
I run chirpstack via docker, so anytime I use the tags latest for chirpstack and chirpstack-gateway-bridge I see this problem - this is not a v3 to v4 upgrade. I just rebuilt this LNS with v4 from the start.
I see master has it containers still set to tag 4, is this on purpose?
I would of thought that as well @bconway, but if i change it to latest it pulls a different container altogether with a different container hash too even, this is what I see for chirpstack - i only get this error on the latest container for gw bridge below if that makes sense.
chirpstack/chirpstack 4 a0bb42598a8b 6 weeks ago 55.3MB
chirpstack/chirpstack latest a0bb42598a8b 6 weeks ago 55.3MB
chirpstack/chirpstack-gateway-bridge latest 375ef145630c 4 months ago 20.6MB
chirpstack/chirpstack-gateway-bridge 4 be4b06183bd2 6 months ago 21.1MB
