Hi I’m using HTTP integration with my application, and I am getting the uplink data from the LNS.
However, I’m not able to send downlinks to my devices. I’m initially testing using postman. Below are the details:
URL : http://LNS_IP_HERE:8080/api/devices/DevEUI_HERE/queue
Headers: ‘Authorization’ : ‘API_KEY_HERE’
Body:
"deviceQueueItem": {
"dev_eui": "*DevEUI_HERE*",
"confirmed": false,
"data": "AQID",
"fPort": 11
I’m getting 400 Bad Request error for the above.
ccall48
2
try adding Bearer ^ before the api key like above.
@ccall48 : Do you mean like this:
This did not work btw. Am I doing something wrong again?
Hi @Ronit_Vairagi
You must set the Grpc-Metadata-Authorization header to Bearer <API TOKEN>.
ccall48
5
@sagarpatel has it correct… try that as the authorization and you should be set.
@ccall48 Yes this is correct please check the below screenshot
system
Closed
7
