ChirpStack v4 with Dragino LPS8 config
Dear All,
Can you help me?
I’m a relative beginner in the subject, so I’m asking for your patience and help. I have a Dragino LPS8 device. I was able to easily set up the connection to TTN (basic station mode). I want to do the same with Chiprstack v4.
I installed it based on this description: docs/getting-started/debian-ubuntu.html
Host machine: Debian 11 (Chirpstack v4 RC4)
I tried to configure Dragino based on the following: Notes for ChirpStack - DRAGINO
ChirpStack dashboard / Tenants / gateways / mygwname / TLS certificate
Under this there is a TLS generate certificate option. It doesn’t work for me!
When I SSH into the server, I see that the config file contains less than the config file in the documentation. (etc/chirpstack-gateway-bridge/chirpstack-gateway-bridge.toml <-> Configuration - ChirpStack open-source LoRaWAN® Network Server documentation)
What do I have to enter and modify so that the cert generation works and I can get the Dragino LPS8 to work?
Best regards,
Joc
The easiest way is to install chirpstack-gateway-bridge on the server and use Semtech UDP at gateway.
You can modify configuration files found on /chirpstack-docker folder manually, using vim or nano text editor.
Another option as datnus suggested is installing gateway-bridge in the gateway itself and use UDP packet forwader.
Best wishes,
Nico.
