ChirpStack with P-NUCLEO-LRWAN2
Hi Everybody! We would like to use the ChirpStack software pack with P-NUCLEO-LRWAN2 gateway. But I does not see this gateway in the gateway list. Do you have any experience about this P-NUCLEO-LRWAN2 gateway and ChirpStack software pack?
Info about P-NUCLEO-LRWAN2 pack:
Thank you very much your answers.
due to the limited abilities of this controller,
there are no linux distributions for STM32 controllers, which can run chirstack components on it.
You can use builtin basic packet forwarder only.
Hi eugenev!
Thank you for your help and answer.
If I understand you. I can use this ST gateway with chirpstack sw pack, if this gateway has a packet forwarder capability.
I have checked the gateway’s datasheet and I have found this description:
Do I understand well?
Thank you.
Any gateway has packet forwarder function. Otherwise it wouldn’t be a gateway. You can use it with any LoRaWAN server, deployed at other side (in the cloud or dedicated host, I mean)
Thank you very much. I will try it.
