I’m currently facing issues while integrating ChirpStack with ThingsBoard. I want technical help with the same. It’s urgent.
This is a community forum, so I’m not sure that you are in the correct place to require urgent consulting services.
Please describe your problem precisely, and then, someone may take a couple of minutes of his free time to help you.
I’m not able to integrate ChirpStack with ThingsBoard. I don’t understand, which is the ThingsBoard access token which I need to add for integration?
Hi
In TB, you have an access token for each device:
Then, in Chirpstack, you must add a variable named “ThingsBoardAccessToken” for each device, with this access token.
