Hello, we are new in loraWan tech, We have a Cisco gateway IXM-LPWA-900-16-K9 with version 2.2.0 trying to use basic station on port 3001.
Our chirpstarck enviroment is over docker, using docker compose
We are stacked with the basic configuracion. apparentelly the gateway cisco and chirpstack gateway bridge are not finishing the initial handshake.
there are any basic configuration on the chirpstack configuration?
we found the how should be the config of lorawan cisco Cisco - ChirpStack open-source LoRaWAN<sup>®</sup> Network Server
this is the capture:
serv# tcpdump -AUq -i ens192 port 3001
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on ens192, link-type EN10MB (Ethernet), capture size 262144 bytes
15:36:29.961053 IP 10.216.124.201.33728 > LABTNSARLAS330.3001: tcp 0
E…<?@.>.O7
…U…r…
15:36:29.962341 IP LABTNSARLAS330.3001 > 10.216.124.201.33728: tcp 0
E…<…@.?..v
.|…X.U…t…
15:36:29.962815 IP 10.216.124.201.33728 > LABTNSARLAS330.3001: tcp 0
E…4@@.>.O>
…U…X…*…
15:36:29.962841 IP 10.216.124.201.33728 > LABTNSARLAS330.3001: tcp 169
E…\A@.>.N.
…U…X…
.$… GET /router-info HTTP/1.1
Host: 10.218.254.202:3001
Upgrade: websocket
Connection: upgrade
Sec-WebSocket-Key: bpse8nVmEl6ZlX4lSb6RMw==
Sec-WebSocket-Version: 13
15:36:29.962909 IP LABTNSARLAS330.3001 > 10.216.124.201.33728: tcp 0
E…4).@.?..
.|…X.U…l…
15:36:29.963254 IP LABTNSARLAS330.3001 > 10.216.124.201.33728: tcp 129
E…).@.?..;
.|…X.U…
.$HTTP/1.1 101 Switching Protocols
Upgrade: websocket
Connection: Upgrade
Sec-WebSocket-Accept: SbMU0fxpAshBk4AeqnJgtXX4CeQ=
15:36:29.963535 IP 10.216.124.201.33728 > LABTNSARLAS330.3001: tcp 0
E…4\B@.>.O<
…U…Y…)…
15:36:29.967220 IP LABTNSARLAS330.3001 > 10.216.124.201.33730: tcp 1602
E…vq.@.?.3.
.|…+@.t…
.$.~.>{“msgtype”:“router_config”,“NetID”:null,“JoinEui”:null,“region”:“AU915”,“hwspec”:“sx1301/2”,“freq_range”:[915200000,927800000],“DRs”:[[12,125,0],[11,125,0],[10,125,0],[9,125,0],[8,125,0],[7,125,0],[8,500,0],[-1,0,0],[12,500,1],[11,500,1],[10,500,1],[9,500,1],[8,500,0],[7,500,1],[-1,0,0],[-1,0,0]],“sx1301_conf”:[{“radio_0”:{“enable”:true,“freq”:917200000},“radio_1”:{“enable”:true,“freq”:918200000},“chan_FSK”:{“enable”:false},“chan_Lora_std”:{“enable”:true,“radio”:0,“if”:-200000,“bandwidth”:250000,“spread_factor”:7},“chan_multiSF_0”:{“enable”:true,“radio”:0,“if”:-400000},“chan_multiSF_1”:{“enable”:true,“radio”:0,“if”:-200000},“chan_multiSF_2”:{“enable”:true,“radio”:0,“if”:0},“chan_multiSF_3”:{“enable”:true,“radio”:0,“if”:200000},“chan_multiSF_4”:{“enable”:true,“radio”:0,“if”:400000},“chan_multiSF_5”:{“enable”:true,“radio”:1,“if”:-400000},“chan_multiSF_6”:{“enable”:true,“radio”:1,“if”:-200000},“chan_multiSF_7”:{“enable”:true,“radio”:1,“if”:0}},{“radio_0”:{“enable”:true,“freq”:917200000},“radio_1”:{“enable”:true,“freq”:918200000},“chan_FSK”:{“enable”:false},“chan_Lora_std”:{“enable”:true,“radio”:0,“if”:-200000,“bandwidth”:250000,“spread_factor”:7},“chan_multiSF_0”:{“enable”:true,“radio”:0,“if”:-400000},“chan_multiSF_1”:{“enable”:true,“radio”:0,“if”:-200000},“chan_multiSF_2”:{“enable”:true,“radio”:0,“if”:0},“chan_multiSF_3”:{“enable”:true,“radio”:0,“if”:200000},“chan_multiSF_4”:{“enable”:true,“radio”:0,“if”:400000},“chan_multiSF_5”:{“enable”:true,“radio”:1,“if”:-400000},“chan_multiSF_6”:{“enable”:true,“radio”:1,“if”:-200000},“chan_multiSF_7”:{“enable”:true,“radio”:1,“if”:0}}]}
15:36:29.967610 IP 10.216.124.201.33730 > LABTNSARLAS330.3001: tcp 0
E…4#.@.>…k
…+@.t…{…
15:36:29.974044 IP 10.216.124.201.33730 > LABTNSARLAS330.3001: tcp 8
E…<#.@.>…b
…+@.t…
15:36:29.974773 IP LABTNSARLAS330.3001 > 10.216.124.201.33730: tcp 4
E…8q!@.?.9Y
.|…+@.|…p…
15:36:29.975171 IP 10.216.124.201.33730 > LABTNSARLAS330.3001: tcp 0
E…4#.@.>…i
15:36:29.975275 IP LABTNSARLAS330.3001 > 10.216.124.201.33730: tcp 0
E…4q"@.?.9
.|…+@.}…l…
